Marlin Crawler - Exploring our new MC07 XD Dual Case Technology
We redesigned our Dual Case Adapters last year with our new line of Xtreme Duty adapter plates. I never got this posted here, so here goes!!
Exploring the New MC07 XD Technology
To compliment our Xtreme Duty 4.70:1 Gear Set, Marlin Crawler is proud to release the long anticipated Xtreme Duty Dual Case Adapter Kit. The Xtreme Duty 4.70:1 turned the Low Range gear world up-side-down, and now it is time for the world's #1 most popular dual case adapter kit to do the same.
Originally created in 1994, the Marlin Crawler Dual Case Adapter has come a long way since its introduction as the MC01. Please take a moment to explore the technology behind the most advanced Dual Case Adapter in the world...
Features
The key ingredient in the reliability and longevity of the dual case adapter is how the coupler is supported. Knowing this important fact, Marlin incorporated a large, double roller bearing into his first dual case adapter in 1994. The manufacturer at the time refused to use such a large bearing instead opting for a cheap, in-house part. Finally in 1997, Marlin had enough stripped out couplers to finally convince his manufacturer to use a double roller bearing.
This was a critical turning point in the dual case adapter world. The double roller bearing has been proven to be over 100 times more reliable than a single roller bearing. The double roller bearing is so successful in fact, that it is used in our MC08, MC09, MC10, MC11, and MC12 dual case adapters.
2. Chromoly Coupler
You read that right: The XD MC07 Crawler comes with a Chromoly Coupler. This is Xtreme Duty, this is Marlin Crawler.
3. Oversized Heavy Duty Cage Bearing
This is another Marlin Crawler Xtreme Duty exclusive feature. We have seen some lower cage bearings overheat in extreme conditions, such as heavy trail breaking in deep snow or mud. You might think the snow would keep the case cooler, but what happens is the snow melts around the drivetrain and then freezes into ice creating an insulating layer around the transfer cases. This prevents any air flow around the cases and, in turn, the gear oil temperature begins to rise. The Xtreme Duty Crawlers feature this MASSIVE lower cage bearing to combat this issue.
4. Radiused Coupler for increased pocket bearing oiling
The input pocket bearing is housed within the coupler. Because this pocket bearing is above the gear oil fill level, it is important to get the right amount of oil to the pocket bearing. Our 4.70:1 Xtreme Duty low speed gear does features an innovative oil pump system, however 4.70:1 gears are generally not used in a Crawl Box. For this reason, we have designed our Xtreme Duty coupler to encourage oil flow through the pocket bearing while at the same time trimming off fat.
5. Heavy Duty Plate Webbing
The Xtreme Duty adapter plate lives up to it's name with full flange webbing. The previous designs stopped short of each flange, but not the Xtreme Duty design.
6. Thrust Washer Lock System
Please imprint these words into your brain: Every Toyota thrust-washer has a detent ball lock system. Period. Every main shaft in every transmission Toyota has ever built has a locked thrust washer-to-shaft system: All L-series, all G-series, all W-series, all R-series. Additionally, every transfer case they have made uses a thrust washer-to-shaft lock system including all 4-cylinder and 4-cylinder Turbo gear drive cases, and all chain drive cases including those found in Tacomas, 4Runners, T100s, FJ-Cruisers, and Tundras. Heat treated same-metals should NEVER be allowed to wear against one another.
7. Shelf Oil Passages
Our adapter plates are designed with 6 oil passages between the transfer case and the Crawl Box. The upper two oil passages are above the oil fill level so only turbulent oil is able to transfer through these passages. Because of this, we've designed our Xtreme Duty Crawler plates to include shelves to "catch" and drain this oil right into the upper oil passages.
Our previous design lacked shelves and therefore relied on vehicle acceleration in order for gear oil to pass beyond the main bearing. Unlike other adapters, the Xtreme Duty adapter transfers oil under cruising conditions. This never before seen feature is only available with a Marlin Crawler.
8. Multi-bolt Retention System
When we invented the multi-bolt retention system back in 1999, we knew it would be a world class feature. That is why 7 of our dual case adapter kits use this innovative Marlin Crawler feature. Some competitors try to emulate Marlin Crawler, but the fact is Marlin Crawler has been using this design for more than a decade.
Technically speaking, 1 bolt would suffice since the tensile strength of the grade 12.9 bolt far exceeds the axial loading forces of the low speed gear, but we wanted to spread the load across the snap ring while providing an esthetically appealing final product. Our design was changed from a 3-bolt system to a 4-bolt system because the larger Xtreme Duty lower cage bearing prevented an equal 120-degree 3-bolt offset pattern, but allowed for a 4-bolt 90-degree offset pattern. The rest is history.
9. Proper JIS Heavy Duty Fasteners
Marlin Crawler has used Japanese Industrial Standard (JIS) hardware since 1994 and will continue to do so. Your Toyota truck doesn't have any 13mm, 15mm, 1/2in, 5/8in, or 11/16in bolts so why should a dual case adapter have non-Toyota hardware? You drive a Toyota, you only carry tools to service your Toyota. Marlin Crawler takes great pride in using the proper hardware for the job. Additionally, you won't see us using any nylon locking nuts because it is common for the nut to lock to the stud in such a manner that the stud gets extracted with the nut. And since the adapter flanges are so close to one another, you can't get the nut off of the stud in order to get the housing off of the adapter plate! Sheesh! Also, the nylon cracks and degrades over time causing the nut to simply unthread. Toyota uses flat & lock washer combinations all over your truck so it is only natural for Marlin Crawler to use the same. Don't get "screwed" with inferior mounting hardware!
10. CAD Optimized Light Weight Adapter Cut Out
Using the latest in computer software, we were able to reduce the weight of the adapter plate by an incredible 25% without sacrificing any strength! The adapter cut out also allows for other advanced features such as the shelved oil passages.
11. Unique Margasket
We have been providing our very own Margaskets for over half a decade now. These gaskets are unique due to their universal nature. You don't have to second guess which gasket to use with which donor transfer case, we've taken all of the guess work out of the install process. Marlin Crawler customers appreciate the attention to detail of our products.
12. EcoSeal Transmission Output Seal
The EcoSeal needs little introduction. This heavy duty replacement transmission output seal has a metal flanged lip to ensure a full installation into your transmission's tail-housing. This prevents installing the seal sideways/crooked, a severe installation error that reduces the life expectancy of the seal as well as the sealing effectiveness. The EcoSeal eliminates installation errors ensuring the job is done right the first time. A transmission rebuild is expensive; keep your transmission and transfer case gear oil separated.
Conclusion
After examining the most feature rich and technologically advanced Toyota RF1A dual case adapter kit in the world, we are certain you will agree that the new Marlin Crawler Xtreme Duty MC07 is on a completely different level far, far above all the rest. There simply is no comparing a Marlin Crawler with any other.
This new XD adapter is available in both standard & 10-degree rotated versions, cast aluminum (MC07-XD) or billet aluminum (MC08-XD) versions. Our chain drive adapters have many of these same features as well, including our Hilux chain drive billet adapter (MC10-XD), Tacoma/Tundra/FJ-Cruiser/4Runner chain drive billet adapter (MC09-XD), and our newest MC11-XD which is for 4.0-liter applications (currently only available for autos).
Click here for our full dual case adapter line-up: http://www.marlincrawler.com/transfe...s/dual-t/cases
Features
- Double Roller Maximum Capacity Main Shaft Bearing
- Chromoly Coupler
- Oversized Heavy Duty Cage Bearing
- Radiused Coupler for increased pocket bearing oiling
- Heavy Duty Plate Webbing
- Thrust Washer Lock System
- Shelf Oil Passages
- Multi-bolt Retention System
- Proper JIS Heavy Duty Fasteners
- CAD Optimized Light Weight Adapter Cut Out
- Unique Margasket
- EcoSeal Transmission Output Seal
- Proven to be over 100 times more reliable than a single roller bearing design.
- 158% stronger than competitor's single roller bearing.
- 256% less load per ball due to its high 32-ball count.
- The only dual case adapter in the world with a double roller bearing.
- The only dual case adapter in the world with a maximum capacity bearing.
2. Chromoly Coupler
- Chromoly Coupler adds extra strength where it is needed the most
- Stronger material provides exceptional spline wear characteristics
- 84% more massive.
- 52% stronger load rating.
- 42% larger rollers.
- 13% higher speed rating (not applicable in terms of crawling, but this shows it's superior heat dissipation).
- Increased pocket bearing oiling.
- 13% lighter coupler.
- Lighter coupler enables improved bearing support.
- More strength to hold the two flanges together.
- Improved plate rigidity for extreme operating conditions.
- Prevents unnecessary wear.
- Reduces the amount of metal debris in your gear oil.
- Prevents unnecessary heating of thrust washer and coupler.
- Extends the life of the coupler, thrust washer, gear oil, gears, and bearings.
- Shelves catch and direct turbulent oil to flow passages.
- Transfers oil under cruising conditions, a never before seen feature.
- With a total of 6 flow passages, the Xtreme Duty adapter flows the most amount of oil.
- Marlin Crawler invented the multi-bolt retention system in 1999.
- Over a decade of experience in 7 different adapter kits.
- 1 bolt would be sufficient, but multi-bolts provide an appealing final touch.
- Using JIS compliant hardware since 1994.
- Flat & Lock Washer combo is standard Toyota practice that far outlasts locking nuts.
- Clearance around nuts provide access to nuts using a box-ended wrench (see image below).
- Keep your non-Toyota tools at home!
- CAD optimized material removal yielded a 25% lighter product.
- Supports advanced adapter features such as shelved oil passages not found anywhere else.
- Universal Margasket fits any donor case no matter the shift style or year.
- Removes all the guess work of which gasket to use with which donor case.
- EcoSeal eliminates installation errors.
- Longer life expectancy and improved sealing.
- Marlin Crawler has been including complementary transmission output seals since 1994.
Conclusion
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
