Prerunner & All 2WD Rigs Discussions pertaining to non 4WD rigs
02 tacoma thermostat
Old 12-29-2012, 10:50 AM
yamaboy03's Avatar
I just put a new radiator in and pulled off the thermostat housing. Couldn't pull the thermostat out. Is it just stuck in there or is there a trick to it?
Old 12-29-2012, 11:32 AM
rworegon's Avatar
No trick. They just sit in the housing with the gasket around the t-stat.
Old 12-29-2012, 01:38 PM
aa1911's Avatar
yep. And when you get it out of there, if you are replacing it, make sure to use a stock toyota Tstat not an aftermarket; the toyota ones have a much bigger hole allowing more flow, not too expensive either.
4x4YOTA
08-23-2016 09:08 AM
Project90
09-24-2015 11:40 PM
LotOMiles
09-14-2015 11:45 PM
noahstancik
09-10-2015 10:47 AM
--Oz--
09-06-2015 01:06 AM
Quick Reply: 02 tacoma thermostat
