Vendors Build-Ups (Build-Up Section) Vendors can showcase customer builds here
toyotafiberglass - Mojave tribute build
Old 04-21-2015, 04:08 PM
  #41
slacker's Avatar
hahaha .. I have more people going ... whaaaatt on the engine color then anything else .. love it !
guess you'll have to wait and see just what I'm talkin' 'bout
Old 04-22-2015, 07:21 AM
  #42
Staff
kawazx636's Avatar
I think it will look fancy! But I think it would look better with 24K gold flake! Go big or go home!!
Old 04-22-2015, 04:57 PM
  #43
slacker's Avatar
yeah ... no ! hahahahah
Old 04-24-2015, 04:30 PM
  #44
slacker's Avatar
C-3PO's cousin
Old 04-29-2015, 04:31 PM
  #45
slacker's Avatar
Joel still workin' on the frame ... almost ready !!
Old 04-30-2015, 10:23 AM
  #46
Staff
kawazx636's Avatar
You sticking with the IFS or going SA? Please say IFS so I know that you are still a Toyota purist... :o) Doing my frame was perhaps the most annoying part of my build! The entire frame was thoroughly covered with that nasty tar-like undercoating that was popular around here in the late 80's/early 90's. Talk about a major PITA to remove!!!
Old 04-30-2015, 11:27 AM
  #47
Staff
Terrys87's Avatar
I wondered how you did yours. I do the same thing. Getting in all the nooks and crannies takes a while but about the only way I know of doing it with out blasting it. Drive train looks great.
Old 04-30-2015, 04:10 PM
  #48
slacker's Avatar
yep , sticking with the IFS ... I do have a new IFS suspension lift going in though , but yep , IFS
this is not the way I do it normally do it ... usually I start with a bare frame , sand blast it , and go from there . My trekker I didn't sandblast , but it was a real nice , nice frame to start with . I really wasn't planning to go this far , but I just cant seem to come to terms with just letting the "little things" go .. I seem to need to fix them ... I think I have some sort of disease or phobia
  #49
slacker's Avatar
Joel has been a huge help on this .. and to keep up with him today we had to mount the tranny and engine to get the positioning for the new mounts .
I used some round tube I had , worked out great ...
Old 05-02-2015, 03:41 PM
  #50
slacker's Avatar
engine and tranny back out .. time to finish up the frame .
and front end reduced to just a pile of parts
and with a little more work we're almost ready for the POR15 treatment
Old 05-03-2015, 04:56 PM
  #51
slacker's Avatar
ok , so now we're done with the fitting of the engine .. time to make it perdy
first I started with removing the pan .. for those whom don't know , the original oil pan and pick up on the 5Vzfe wont fit this application . so as you saw in the previous pictures , I already powder coated the pan I need ..
With the pan off , I can now drill the new dipstick location .. and install the new holder
installed with a little red LOCKTITE just for "piece of mind"
also removed the "front end" to replace with all new parts
new oil pump , water pump , timing belt , bearings ect .......
Old 05-04-2015, 07:23 AM
  #52
Staff
kawazx636's Avatar
Are those "cheater marks" on the cam gears that I see so you don't have to re-do the timing later?? Just kidding, I do the same thing!!! HAHA! I hate having to re-time dual cams!
I really need to get some of that chrome powder to give it a whirl! That stuff looks really good - makes the gold pop really nice too! I particularly like how it looks more like polished and cleared aluminum than it does chrome (or at least that his how it come across in the pictures)
Old 05-04-2015, 04:09 PM
  #53
slacker's Avatar
of course ....
I ordered some clear coat for the chrome powder , suppose to make it look more like chrome . I was kind of going for a gold and silver look , on these , and I think I have achieved exactly that ? I'm really happy with the colors , and I think it's going to go great with the brown engine bay color and exterior
Old 05-04-2015, 05:23 PM
  #54
slacker's Avatar
frame is all "prepped" now ... acid etched and washed
wheeled it into the shop , and all prepped for tomorrow
should be black tomorrow
Old 05-05-2015, 03:11 PM
  #55
Staff
Terrys87's Avatar
You do have every nut and bolt out of that frame. You are making some quick work on this truck.
Old 05-05-2015, 04:56 PM
  #56
slacker's Avatar
yepers ...
Old 05-05-2015, 05:02 PM
  #57
slacker's Avatar
check this out
[YOUTUBE]
[/YOUTUBE]
Old 05-05-2015, 05:09 PM
  #58
slacker's Avatar
done and curing overnight
Joel spraying , and I used the pressure pot to do the inside of the frame
and the "machine" cleaning the front diff ..
Old 05-07-2015, 04:13 PM
  #59
slacker's Avatar
got the rear in .. just loosely , nothing torqued yet
blasted the front A arms , and some powder and new bushings
started installing the new lift , and got the front diff in place
Old 05-08-2015, 05:49 PM
  #60
slacker's Avatar
little more today ..
still working on the front lift , so got the crossmembers , shocks , sway bar , axles , and a few other things
also checked the rear harness for damage , and re wrapped
POR15'ing the frame , you need to remove all the "lock" clips , so this is what I use to lock the harness into place
straps not yet tightened , as I may need to move the harness one way or the other
Quick Reply: toyotafiberglass - Mojave tribute build
