Looking For A Mechanic/Fabricator/Shop Put your location in your thread title when making an inquiry
Toyota Engine / Carb tuning in OR
Old 08-18-2014, 10:12 PM
1st Gen Crawler's Avatar
I am looking for a reputable place to get my Toyota engine tuned once and for all. I have tried all sorts of stuff, and have gotten it pretty close, but i think there is still more power to be had from my 22r and all its mods. (check signature for mods). Once, i decide between a new weber 32/36 or 38 (leaning for the 38) i will pretty much have completed my engine aside from electrical components such as a new performance distributor.
Anyways, i need a good local shop that i can take my 22r to to get it tuned. I want the whole works, what sort of things should i have done? i want the timing checked, and set accordingly, i want to check my compression, and basically have a full check up on the status of my engine to point out any weak spots, or places that i am losing power.
Old 08-19-2014, 10:08 AM
enigmaT120's Avatar
Where in Oregon are you? I've never had any of my rigs professionally tuned, but if anybody has it may make a difference if you're in Portland or Baker City. Unless you get a lot better mpg than I do!
Old 08-19-2014, 06:04 PM
gillesdetrail's Avatar
I don't know what it's like in oregon but around here only the old italians can tune webers, and almost all of them have been out of the game since the 90's! I think the best place you can have that carb tuned is at a motorcycle shop, because if you find someone who can tune bike carbs, that person can easily tune a weber because they aren't very hard to tune if you know the basics and specs on idle mixture screw and idle speed screw. You should have that information with you if you find a tuner.
Old 08-19-2014, 06:21 PM
Thanks for the info. i didn't even think of asking a motorcycle shop. good idea. i am located in Corvallis, OR.
JF9243176
10-08-2017 04:21 AM
DacodaYota
09-02-2015 02:13 PM
bigblue82
10
07-06-2015 08:27 AM
kazuya2416
06-27-2015 12:24 PM
Mohamed
17
08-21-2002 12:54 PM
Quick Reply: Toyota Engine / Carb tuning in OR
