mmml4's 1999 4Runner Rebuild/Build-Up Thread
Started with this.
1999 4Runner, 2wd, 3.4 v6, auto. Killed in head-on collision.
Rebuild/build specs:
Replace frame, damaged body panels, damaged engine compartment components.
Front:
SAS with 80 series Land Cruiser axle and coils
3 link with panhard
Ballistic Fab adjustable coil buckets
IFS steering box
Rear:
3 link with panhard
Engine:
3.4 liter 5VZ-FE
Transmission:
80 series Land Cruiser A343F & transfer case running Slee Offroad part time 4 wheel drive kit and manual hubs
Tiptronic type manual transmission shift control
and a whole bunch of other stuff I haven't figured out yet
Front:
3 link with panhard
IFS steering box
Rear:
3 link with panhard
Engine:
3.4 liter 5VZ-FE
Transmission:
Your basic frame plating, instead of plugging all the factory holes or plating over them I just cut mine to match so the space between the frame and the plate would be sealed.
Thanks space-junk, it was very sketchy at first but it has come a long way over the past 2 1/2 years. This is my first build and it has been a huge learning curve.
My first attempt at building links.
Lower links:
I used 1-1/4" Johnny Joints (18mm thru hole) at the frame, custom sleeves with cruiser bushings (18mm thru hole) at the axle, 1-1/4" ladder bar adjuster for fine tuning and a custom square insert 6" long drilled and tapped 1-1/4" left hand thread 4" deep. Tubing is 2x2x1/4" wall.
Lower links:
Upper link:
I used 1-1/4" Johnny Joints (18mm thru hole) at the frame, custom sleeves with a cruiser bushing (18mm thru hole) at the axle, Ballistic Fab 1-1/4-12 righthand chromoly insert.
Tubing is 1-3/4" OD x .120" wall DOM.
Well I got my upper link tacked in place. I ended up with about 5" of separation at the frame and about 6" at the axle. My next step will be to fit the panhard.
Reusing the Cruiser coil perch.
