how to convert s'cab to d'cab?
Old 05-27-2013, 09:28 PM
Fatslobb's Avatar
I have a 1999 3.0L Diesel s'cab ute, and want to keep the good bits, and change the body, either by swapping everything over, or by cut & weld. Assuming both ways are going to take their longest routes, which is easier for a weak-kneed amateur with limited equipment and $?
PS I don't know if the cab/attachments are welded to the chassis. I would need a good description of how to go about it.
thx.
Old 05-28-2013, 03:21 PM
crazypaint's Avatar
Better to find one needing a drive tran or a wreacked on db cab has longer frames. If u have a long bed u could swap a db cab on with a short bed p. then I'd just have to add to the back of the frame a little
Old 05-28-2013, 04:09 PM
Fatslobb's Avatar
THX, I hadn't considered that, I guess because of the cost of getting a late enough rolling chassis. Still, It's an idea. I can go to 2004 and swap wiring forms too I expect, as I definitely want to keep the mech injection.
JustMike
04-21-2016 07:08 PM
Griff
93-98 T100s (Build-Up Section)
09-23-2015 10:11 PM
129Creepin
08-05-2015 10:12 PM
Esibnitsud
07-30-2015 08:19 PM
crashburnoveride
07-10-2015 06:39 AM
Quick Reply: how to convert s'cab to d'cab?
