Yet another "squeak" thread....
Old 10-08-2009, 11:31 AM
vol4runner's Avatar
I've done the search thing and it seems that all the threads that have been started relate to the front end. Well....my squeak is in the rear of my rig. It does it on uneven roads (washboard) and small bumps. I stood on the bumper and running boards and was able to recreate the noise. I'm just not sure where to look first to see what might be causing it. Any suggestions?
Thanks.
Old 10-08-2009, 11:51 AM
Lumpy's Avatar
Springs, bushings, exhaust hanger, mouse...
Old 10-08-2009, 11:57 AM
toyota4x4907's Avatar
Is it a Tacoma or 4runner?
If Tacoma, check the rear leaf hangar bushings.
Have someone else stand on the running boards and bounce it while you lay under or near the rear and listen.
Old 10-08-2009, 12:30 PM
Lumpy's Avatar
Originally Posted by Gnarly4X
Trying to analyze squeaks over the internet is like sniffing flowers through your butt.
Spray some silicon spray all over the bushings and bolts.
TJMWO,
gNARLS.
That would definitely get rid of the mouse!!!
Old 10-09-2009, 04:32 AM
vol4runner's Avatar
Sorry....it's a 97 4Runner.
I realize analizing any problem over the internet isn't easy. I wasn't looking for an exact diagnosis of the problem. Just some ideas of where to start looking.
Thanks.
Old 10-09-2009, 06:06 AM
Lumpy's Avatar
There are a ton of bushing under that thing that could be causing this. Best thing to do is lay under there while someone else jumps on the bumper...
Old 10-10-2009, 06:11 PM
Ron Helmuth's Avatar
my rear squeak was a twisted rear sway bar-at some point in compression it would touch just enough to drive me crazier.
As stated you have to pinpoint the noise more exactly so have the kids/wife/gf jump on the (vehicle) body while you analyze below
Old 10-12-2009, 05:00 AM
vol4runner's Avatar
Thanks guys. I have to do an oil change so I'll check around while I'm under there.
Old 10-12-2009, 06:39 AM
crolison's Avatar
so ya like the vols.....
Old 10-12-2009, 10:46 AM
ericdg16's Avatar
Just an idea...
But start on the driver's side rear and lube one bushing....jump on bumper
if it still sqeaks then lube next bushing....jump on bumper and so on and so forth until it quits sqeaking. At least when you get done all of your bushings will be lubed.
Quattro15
12
03-21-2010 10:32 AM
sinneDBTB
05-06-2009 10:33 PM
Quick Reply: Yet another "squeak" thread....
