Wipers turn on when it rains/washer fluid no longer comes out
Old 08-19-2011, 03:31 PM
yesinokingsu's Avatar
I have a 1997 Toyota Tacoma-v6-ext cab-4wd. My wipers(intermit) work just fine when it is dry out, all settings/timings work. When it snows/rains it will turn my wipers on to medium speed. I cannot turn them off or change speeds. I have no control over them after that. I am thinking it is a short/grounding issue/open wire or does something need replaced? Also my washer fluid no longer works. Has fluid, no leaks, good hoses/lines. What is the best checklist to follow to see what the problem is without replacing part after part. Thank you very much
Old 08-19-2011, 03:57 PM
scuba's Avatar
Check the connections on the pump down at the bottom of the washer fluid tank. Make sure there are no frayed wires or anything.
Old 08-20-2011, 10:07 PM
JBurt's Avatar
You could check the wires in the steering column too.
jasonty
41
12-23-2018 01:00 PM
ghostmoney
01-28-2018 11:42 AM
Up&Down
08-11-2015 10:04 AM
rushw
07-18-2015 01:46 PM
msane99
07-17-2015 10:13 AM
Quick Reply: Wipers turn on when it rains/washer fluid no longer comes out
