will this work...
Old 02-28-2008, 02:08 PM
vsansone_2007's Avatar
will this work...
Im thinking about buying some struts off a stock 08 tundra for my 95.5 tacoma .. does anyone know if they will fit and if they do will they give me any lift
Old 02-28-2008, 02:10 PM
crolison's Avatar
I am going to strongly go with a nope on that one. Not 100% sure, but the new taco and 4runner suspension doesn't work on the older tacos and 3rd gen runners.
Old 02-28-2008, 04:22 PM
mpavolka's Avatar
I would almost guarantee that they will not work, first of all the top plates off the 99-06 Tundras does not even fit the Tacoma/4Runner. If the compressed/extended length is not the same or similar to the 4Runner/Tacoma you risk serious damage to struts,A-arms, CV axles, and tires. However I have no idea, but wouldn't doubt the the springs might be able to be used.
Old 02-28-2008, 04:31 PM
Ironmike4x4's Avatar
My suggestion is if you have the money and are willing to experiement with this then try it. SOMEONE had the idea to put Tundra calipers/rotors to fix the rotor warping problems. Should you decide to do this and it works then post up a write-up. Other examples are the deck plate mod and the rear differential breather mods. A few members here have even put front Tacoma lifts and apparently it works well. Just because some people "aren't 100% sure it won't work" doesn't mean it won't.
Old 02-28-2008, 05:09 PM
BajaRunner's Avatar
The coils will work, as well as the shocks, but, the top-plates are not the same diameter. You'll need to swap the top-plates, and you'll be fine. You should probably see a 1-2" lift...
Old 02-28-2008, 05:14 PM
mpavolka's Avatar
I am just curious if you have looked at the length of them, and it they are similar to the 4Runner/Old Tundra, what would be the benefit over something that knowingly works, say older Tundra parts. I am not trying to be mean, just raising the question.
Old 02-29-2008, 08:04 PM
thanks for all the help.. its not worth the trouble.. thank you thoght for the info it did help.. -vince
Old 02-29-2008, 08:07 PM
fillsrunner4's Avatar
could always do some and some
Old 02-29-2008, 10:12 PM
scuba's Avatar
lol filll
but he may not be that adventureus (spelling? , F IT)
mYnAmEiSmUd
07-20-2015 06:48 AM
darkangel
Domestic Swaps
19
11-19-2014 05:24 PM
b4wheeler
08-25-2008 11:39 AM
MCMLXIX
08-24-2008 03:47 PM
Quick Reply: will this work...
