Will these wheels fit a 99 4runner?
Old 08-24-2007, 07:46 AM
bratliff's Avatar
I can get a smoking deal on these wheels, they are take offs of an 07 Chevy Silverado 4wd... They are 17x9. Will they fit?
if anyone knows what size tires will fit on stock height? I was thinking 265/70/17 but that 9" wheel worries me..
Old 08-24-2007, 01:09 PM
cackalak han's Avatar
9"... I'm thinking you need some serious offset, but I am not sure.
Do you really need a 9" wheel? I'm sure it's a good deal, but if you don't need it, is it really a good deal?
Old 08-24-2007, 01:46 PM
Adam F's Avatar
Maybe, maybe not. The only way your going to know for sure is to put them on your truck. Backspacing could be different, and the center hole opening for the hub could be different too. Also, 2500 and 3500 silverados are 8 lugs so if they are for those it wont work since yours is a 6 lug, which only the 1500 is.
Old 08-24-2007, 10:02 PM
Sloan's Avatar
do you have any lift under your 4runner because i'm thinking it might also scrub a little
Old 08-25-2007, 05:15 AM
bratliff's Avatar
My truck is stock height, stock everything. I dont really need/want a 9" wheel but they are brand new and I can get the set for 200$... They are off a 4wd 1500 so lug wise I know. But the reason I was asking was for the hub size and offset.
I will try them out, but I thought so many of the people on here know soo much that they might be able to say real fast yes/no on the hub size. Also I am trying to find out about what offset they are. I am thinking that they wont have enough offset because of the 9" width, but its worth checking for such a deal.
I appreciate the input.
Bill
Old 08-25-2007, 06:27 AM
Sloan's Avatar
if anything you can get the whole set for 200 dollars i would just buy them and if they dont fit, just turn around and sell them again.
Old 08-25-2007, 08:14 AM
bratliff's Avatar
thats kinda what I was thinking.. my nephew works at a chevy dealership and he is the one that is offering me the deal. They took them off and put a set of 20's on... so they litterally have 10 miles on them.
Old 08-25-2007, 08:30 AM
MillerPKA's Avatar
aside from the deal you just have to think whether or not they'll look good on your truck or not
Old 08-25-2007, 10:55 AM
bratliff's Avatar
I like the wheels, I was looking at a similar style wheel, but painted black.. I will see what they look like on the truck.. I will even take a pic if I remember..
Old 08-26-2007, 06:19 AM
bratliff's Avatar
I found out last night that they have a -12mm offset and the bore diameter is 107.95mm I need to find about the bore dia... There was no markings on the box for the backspacing..
now I just have to get time to go try them on the truck..
Old 08-26-2007, 06:29 AM
KZN185W's Avatar
What about the PCD? Toyotas has 5.5-inch PCD.
Old 08-26-2007, 12:59 PM
bratliff's Avatar
whats PCD?
Old 08-26-2007, 02:37 PM
Adam F's Avatar
Originally Posted by bratliff
whats PCD?
Google search turns up this
http://www.westerntowing.co.uk/acata...lculation.html
Sounds like a European measurement for the equivalent of the bolt pattern (IE 6 on 5.5)
Old 08-27-2007, 03:59 AM
bratliff's Avatar
oh ok.. yeah PCD is the same.
Thanks - AdamF
Old 08-27-2007, 04:40 AM
KZN185W's Avatar
PCD = Pitch Circle Diameter, also known as BCD = Bolt Circle Diameter
06-01-2021 01:51 PM
Cplmike
07-08-2015 08:47 PM
skoti89
07-06-2015 07:45 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Will these wheels fit a 99 4runner?
