Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#41 (permalink) | |||||
Personal
Sales Rating: (0)
__________________
2000 4Runner SR5 4x4 197k CONVERTED to LIMITED - RIP - 2012 SS 1.2 coming SOON! |
#42 (permalink) | |
Personal
Sales Rating: (0)
Quote:
Aaron |
#43 (permalink) | |
Personal
Sales Rating: (0)
Quote:
Maybe one day I'll get around to doing that projector retrofit for you.
__________________
2002 4Runner Sport 4WD My 4Runner Profile Accessories: SS 7.1 Lift Kit, WabFab 1" BL, Modified & Color-matched TJM T-15, Stubb Sliders, FX/TSX HID Projector Retrofit, Tundra Brakes, Hilux Surf Field Monitor, TRD Ivan Stewart Wheels, Yoko Geolanders 265/75s, WeatherTechs, Pioneer HU, LED Tail Lights, JBL Speakers Mods: Disabled DRLs, Disabled Keyless Entry Chirp, AndyMod 2.0, Fog Light Mod, Air Elbow Mod, Rear Diff Breather Mod |
#44 (permalink) |
Personal
Sales Rating: (0)
Ok guys, how are you hooking up the 2 power antenna wires to your new HU? I know this is a diversity antenna setup, but my new HU only has a place for one antenna (I'm assuming the larger one plugs in there). What do I do with the smaller connector from the back glass antenna? Leave it unplugged?
Also, how do I need to wire my new wiring harness so the power antenna goes up when the radio is selected and down when the CD/ipod is selected?
__________________
#45 (permalink) |
Personal
Sales Rating: (0)
Humm... RS I just plugged my antenna into the one slot and left the other one out....as for the antenna going up and down....mine turns on with the radio and that is the only time it will activate....mine JUST broke last weekend so I will need to install a new one....
__________________
#46 (permalink) |
Personal
Sales Rating: (0)
just use the bigger one, I don't really notice any difference with the smaller one unpluged.
#47 (permalink) | |
Personal
Sales Rating: (0)
Quote:
Aaron |
#48 (permalink) | |
Personal
Sales Rating: (1)
Quote:
__________________
98 SR5 4Runner Desert Sand OME 881/890 & 04/27 Shocks Go Gamecocks! |
#49 (permalink) |
Personal
Sales Rating: (0)
#50 (permalink) |
Personal
Sales Rating: (0)
This should be the same as when i installed my avh-p3100dvd basically the same thing but with a smaller screen and bigger buttons but you connect the blue and white wire from the harness that plugs into the back of the HU with the remote wire from the best buy wiring harness, in your case, (mine was from walmart) and that big plug goes into the back of the HU IIRC. Here is a link of the wiring diagram. Go to the installation manual part and its page 7.
http://akamaipix.crutchfield.com/Man...130AVHP410.PDF
__________________
1998 4Runner Limited 4WD, Locker, Supercharged, TRD Cat-Back Exhaust, 99-02 Headlights, 4300K HID Projectors,Pioneer AVH-p3100dvd, 2 RF P3's, Saving for Long Travel |
#51 (permalink) |
Personal
Sales Rating: (0)
Hmm yep I see that I gues when I did my video bypass I just payed no attention to the "remote wire" from the head unit that had to be spliced in to the video bypass thingy. I'll scotch lok the pwr antenna wire to the remote wire and see if that works.
Aaron |
#52 (permalink) |
Personal
Sales Rating: (0)
Aaron, that's what the VM I left you yesterday was about. I found that same wiring diagram on pg 7 of the installation pamphlet that stated the blu/wht wire should be connected the the blue remote wire on the metra wiring harness. Hope my VM was not too confusing
. I've already soldered my blue wires together hoping this works like I think it should. Can't wait for YOU to try it out.
__________________
#53 (permalink) |
Personal
Sales Rating: (0)
Why do I always have to be the guinea pig? I'm not fat just big boned, and I have the big guns so someone else should certainly go 1st.
Aaron |
#54 (permalink) |
Personal
Sales Rating: (0)
No dice, the blue pwr antenna wire to the remote wire does get the antenna up but it stays that way until the unit or vehicle is powered off, this will not work for me. As far as the illum wire I already have them hooked up and no control over the dimmer, now there are two orange wires on the vehicle connector side I have mine wired into the big connector not the smaller one.
Aaron |
#55 (permalink) |
Personal
Sales Rating: (0)
My bad i forgot you wanted it to only come up when the radio is on. Mine is set up to go up when the unit is on so even when an ipod/cd is playing.
__________________
#56 (permalink) |
Personal
Sales Rating: (0)
07 highlander with an eclipse avn4430
I recent bought the Eclipse AVN 4430 navi for my 07 highlander. i brought it to a mechanic to have it put in. the car was brought back to me with the navi fully functional and everything. but it seems to be sticking out from the rest of the car quite a bit, unlike the original stereo which used to be in place. i mean i didnt expect the navi to be a perfect replacement of the stereo system in terms of size, but i also didnt expect it to stick out this much. has anyone had a similar experience? or can anyone advise?
#57 (permalink) | |
Personal
Sales Rating: (0)
Quote:
I shopped my depth prior to ordering a HU, I've seen similar HU's in other 3rd gen 4Runners and also looked their mount depth and made my judgment based on that. While the threaded holes on the side of the aftermarket HU will ultimately determine how far the HU will stick out. So unless they used the furthest back set of mounting holes (sometimes 2 sets) you might be stuck with it and have no wiggle room. Aaron |
#58 (permalink) |
Personal
Sales Rating: (0)
also, i added a rear view camera to the eclipse avn4430 gps system. i know usually when you put the car into reverse, it should automatically activate the camera. but my mechanic said it cant be done and that you have to press the Source button on the unit to change it to "frt" mode to activate the camera. this works without a doubt but i was wondering if my mechanic was correct when he said that it cant be done in any other mode like GPS mode or music mode because right now, when the backup camera is activated, music does not play. any ideas?
#59 (permalink) |
Personal
Sales Rating: (1)
the backup cam should be hooked up to reverse signal, on my pioneer avic D3 it works when you put it rev. or you can hit rear view when you r driving forward and see where you've been or whos following you. pretty cool
__________________
Silver Y2K LTD Runner,265/75 16 Goodyear Duratracs,OME springs/shocks,cornfed spacers front, rear E- Locker,Factory Scooped,Airbox mod,fog light mod, drl mod,Tundra 231mm big brake mod, Brembos,Goodridge S/S lines,Tint, custom TRD decals, 02 tails, Pioneer Avic D3 with reverse cam, MB Quart spkrs, infinity basslink, trucool trans cooler, seat bolt mod, Weathertech floor mats, Magnaflow muffler, over 325,000 miles and still awesome |
#60 (permalink) |
Personal
Sales Rating: (0)
My Pioneer doesn't do it, well it might if I had it hooked up like it supposed to but I'm utilizing a bypass that keeps the unit thinking its always in park to allow dvd play while driving. I'm using multiple cameras and have to push the rear view button to get a picture while backing up. Some do it and some don't, when in doubt RTFM (read the freaking manual) it will be in there for sure or download it from pioneer.
Aaron |
| Tags |
| 4430, 6620, avn, avn6620, bypass, chevy, din, double, double din, eclipse, fit, pioneer avh-p4000dvd, radios, silverado, toyota, tundra |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Double Din to Din stereo install?? | Quattro15 | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 07-21-2008 08:30 AM |
| Double Din Stereo In 95 Runner | shansethp | 86-95 Trucks & 4Runners | 7 | 08-27-2007 03:50 AM |
| Can I swap out my OEM Double-Din HU for an OEM Single-Din HU? | Rock Slide | Vehicle Audio & Home Entertainment | 3 | 08-06-2007 07:24 AM |
| Double Din Install | ks2721 | Vehicle Audio & Home Entertainment | 0 | 01-02-2005 08:53 PM |
