| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Will a 97 4x4 rear diff fit a 1997 2wd rear?
#2 (permalink) |
are you talking about the 3rd member only? or what? if they are bot hte 8" rear end, then yes they will fit... however, i dont know much about the tacos, and i think that they will not fit due to hearing something about the non trd tacos having like an 8.4" rear end.... not 100% sure on this
#3 (permalink) | |
Quote:
#4 (permalink) |
Non-TRD Taco's (2wd and 4wd) with a V6 should both use the same diff as the Tundra and T100. The so-called 8.4" diff that is really 8".
So yes, a '97 4x4 Taco rear diff should fit a '97 Taco V6 2wd rear. I believe the 2wd 4cyl is different though.
__________________
- Erik '86 44runner, '97 T100, '97 4runner, '05 WR450 http://home.4x4wire.com/erik |
#5 (permalink) | |
Quote:
#6 (permalink) |
Do you have the 2wd "work" truck or the 2WD Prerunner. They are different and have different 3rd's and different axles all together.
The "work" trucks have 7.5" rears. While the PreRunners could have 8" or 8.5" depending on what options you have.
__________________
Steve Schaefer WWW.SonoranSteel.Com Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer * TOYTEC Dealer * and like everyone else a Trail Gear Dealer |
#7 (permalink) | |
Quote:
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
AFAIK, only the 2wd Taco's w/ the 2.4L engine have the 7.5" diff and the rest have the Tundra style diff.
Here's the easy way to check- are the bolts holding the 3rd member to the axle housing 14mm nuts with 10mm studs or 12mm nuts on 8mm studs? 14mm nuts = Tundra style diff. Also, the diff "covers" look different since the Tundra style diff has the big bearing cap braces. Tundra style on the left, older 8" style on the right:
__________________
#10 (permalink) | |
Quote:
If you have a Prerunner, then you can swap in any complete 4x4 Tacoma Rear (they are all 6 lug). If you just want the 3rd member, then you need the "8.4" 3rd (non e-locker). If you want the e-locker rear, you can wire the locker or get a cable to engage it. You can find a complete e-locker rear for around $700.
__________________
2000 UZJ100 Land Cruiser 2" OME and 33" Geolander AT's Blue Ribbon Coalition Toyota Land Cruiser Association |
#11 (permalink) | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1997 FZJ80 Low Pinion eLocker Diff or Rear Axle | Discyota | The Classifieds GraveYard | 1 | 10-11-2006 07:58 PM |
| New Rear Springs...'97 2wd | phattey | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 05-30-2006 07:38 PM |
| Will Taco Trd Lsd Rear Fit Into My 1997 4runner With 410s? | BOSTON4RUNNER | Offroad Tech | 7 | 04-18-2005 08:23 PM |
| Will a 1997 4Runner rear diff fit in a 1994??? | EOD30 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 10-22-2004 01:47 PM |
