| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Why does my oil smell like gas??
#2 (permalink) |
what vehicle do you have? if its a mechanical fuel pump and you have a carb, thats possible.. but the gasket shouldnt have anything to do with it unless the mechanical fuel pump is internally damaged or leaking...
you have fuel in your oil... menaing your rings are bad or there is some type of leak somewhere.... |
#5 (permalink) |
you dont have t obe losing any power to have leaky rings or a bad head gasket... the point is its contaminated and something is wrong
#6 (permalink) |
right . how can i check these things..plugs maybe
#7 (permalink) |
you might want to do a compression test.... also, do you have a mechanical fuel pump with a carb or is your truck efi?
#9 (permalink) |
does your engine leak any oil? the reason i ask is because my fuel pump leaks oil... yup... oil into the engine bay... so its very possible i jsut almost have the opposite problem... but the same... the fuel pump has 2 little holes under its big head... well these holes on mine, oil drips out of them... dont know why...... its a pretty constant drip but my truck really doesnt lose that much oil and it doesnt seem contaminated...
#10 (permalink) |
Staff
Probably the fuel pump.
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) |
#11 (permalink) |
oh yeah, in case i made it unlear.. im thinking bad compression/head gasket or fuel pump... i would replace the fuel pump forst.. its cheaper...
#12 (permalink) |
Do you get lousy mileage? Maybe carb rebuild time? Maybe too much fuel is washing down the cylinders? Seen this more than once with a fuel injected vehicle, but it ran poorly and the mileage went way down. The only time I ever heard of it with a carb was when some fool put a HUGE carb on a stock small block. Ran poor and sucked fuel too. He finally listened to reason when he started smelling gas in the oil... Just another thought.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
#13 (permalink) |
How many miles are on it? Are you checking for the smell under the oil cap or after you drain it? A little fuel smell in the oil is normal for a high mileage 22r.
Have you replaced the two gaskets between the fuel pump and the head yet? There's a thin gasket on both sides of the fuel-pump spacer. |
#14 (permalink) | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rough idle, white smoke, clean oil, losing water, and gas like smell from radiator??? | kmchby76 | 86-95 Trucks & 4Runners | 10 | 03-05-2007 08:28 AM |
| smell of gas? | ken914runner | 86-95 Trucks & 4Runners | 5 | 11-28-2006 04:00 PM |
| I smell gas! | bsebllhglyknit | 86-95 Trucks & 4Runners | 3 | 07-10-2006 09:25 PM |
| Strong smell of gas...not exhaust...GAS! | vegascoug | 86-95 Trucks & 4Runners | 21 | 05-01-2006 07:45 PM |
| Gas smell...where is it? | Toddski | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 02-10-2004 09:52 PM |
