what's up with this ball joint??!!!
Old 05-18-2013, 04:15 PM
2Whlin's Avatar
trying to remove upper ball joint so I can add a Daystar lift kit and used every tool in the garage to no avail. The ball joint boot is shredded now that we used every pickle fork we had and lubed and pried and beat it into submission but dam thing won't budge. Tried every angle and option so now I have to take it to a shop because I give up!!! Anyone else have this happen??
Old 05-18-2013, 04:42 PM
toyota4x4907's Avatar
Upper ball-joints are press-fit. You need a press. And there is also a snap ring
Old 05-18-2013, 10:42 PM
turbo8's Avatar
Are you trying to separate the ball joint from the upper arm? Use a ball joint puller or pitman arm puller, pretty sure the pitman arm puller works from autozone.
If you're just trying to gain some droop to stick the longer shock in there, use the stock bottle jack to "flex" the arms down. Put the bottle jack on top of the upper ball joint nut and wedge it between the inner fender and jack it up, it should droop the suspension down some so you can bolt the shock in.
Old 05-19-2013, 04:25 AM
Texas_Ace's Avatar
Ditto, used a combo of the puller/pitman arm and after getting the technique down they popped out without too much trouble.
Old 05-20-2013, 09:05 AM
2Whlin's Avatar
Trying to seperate the joint at the upper a-arm. 'll have to look into the puller tool.
Old 05-20-2013, 09:06 AM
2Whlin's Avatar
I'll try the bottle jack trick on the other side, but still going to have to remove that one ball joint as I screwed up the boot using the pickle fork tool!!! Can I just put some grease in there and put a new boot on and be done with it??
Old 05-22-2013, 11:37 AM
leid's Avatar
OP,
Look at the Harbor Freight front end/ball joint tools & set-up I used to remove/install 1997 Tacoma 4WD pressed-in UBJs: https://www.yotatech.com/forums/f2/g...joints-268729/ You can rent the necessary tools at Advanced Auto, etc. or buy them at Harbor Freight, etc. It's easy but only with tools designed to do this job.
HTH & Good luck
Old 05-23-2013, 11:38 AM
2Whlin's Avatar
cool, I need to find that puller as a buddy brought over a pitman puller and it won't work. Won't fit over the upper a-arm.
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
4x4YOTA
08-23-2016 09:08 AM
crash813
09-27-2015 07:15 AM
Odin
09-26-2015 06:56 PM
Quick Reply: what's up with this ball joint??!!!
