What's this connector on front timing cover
Old 02-28-2012, 07:06 PM
rworegon's Avatar
Hope you find it's an easy fix.
Old 02-29-2012, 10:52 AM
vasinvictor's Avatar
It's there! I plugged it in, but poor trucks runs badly still, but that's for another thread. Thanks all.
Old 02-29-2012, 11:39 AM
Replicant's Avatar
Glad to see you found it, sorry to hear it still runs bad. I havent followed your build thread as I am not on here often, what are the symptoms?
Old 02-29-2012, 12:12 PM
mt_goat's Avatar
Ohm out the sensor and see if its in spec, spec range is 835-1400 Ohms between those 2 male posts on the connector.
Old 03-01-2012, 09:41 AM
  #25
Just an update. So it seems that the computer needs B+ to run properly. I checked my wiring 20 times probably and missed B+ (pin 23) in the E12 plug every damn time. Motor runs GREAT! And you the 5vz is so much more fun to work on than the 3.0! Yippe I'll be out driving...
Old 03-01-2012, 09:46 AM
  #26
Replicant's Avatar
Seems like B+ is killing everyone, thats what I had to track down to get mine running. Glad you got it working! Enjoy!
Old 03-10-2012, 04:10 PM
  #27
Bigblock's Avatar
BTW the 3.4 will run flawlessly WITHOUT the cam position sensor.
Old 03-10-2012, 05:06 PM
  #28
Good info thanks
voiddweller
19
05-02-2016 09:10 PM
jennygirl
11-17-2015 11:24 AM
Ichneumon
09-27-2015 04:21 PM
puddlepirate
06-30-2015 05:08 PM
Badger62811
06-26-2015 09:26 PM
Quick Reply: What's this connector on front timing cover
