What was the worst throttle body you've ever seen?
Old 08-20-2004, 07:34 PM
Tacoma Dude's Avatar
Getting set to clean the throttle body tomorrow... this truck has a LOT of carbon buildup and I am anticipating quite a chore tomorrow.
What's the worst you guys have ever seen?
Is it possible to have it black and sludgy?
What are the dangers to the engine with loose sediment and/or black sticky sludge?
Old 08-20-2004, 08:19 PM
miket223's Avatar
Black and sludged is very common. Just stick to the carb cleaner and a bottle brush to clean the walls. The engine will chew up and spit out any chunks of carbon and make quite a smoke show doing it.
Old 08-20-2004, 09:39 PM
Ah interesting...
That's a comfort knowing. If I see it tomorrow I won't be too alarmed then.
I would take off the entire throttle body but I'm not sure I feel up to the task of going out of the way to get a replacement gasket.
Yeah, I'm lazy
Old 08-20-2004, 10:24 PM
rimpainter.com's Avatar
You better port that puppy while it's out Peter!
Old 08-21-2004, 08:37 AM
az4x4runner's Avatar
You should have seen the one on the old '89 Mustang I use to have when I first got it. Didn't know it was possible for the intake system of a car to be that nasty.
Old 08-21-2004, 11:59 AM
86toyota's Avatar
I took these before and after pics back in May.
Old 08-21-2004, 12:23 PM
kyle_22r's Avatar
i'm no expert on fuel injection, but isn't that just about the outermost component on the engine, and only air goes through it? how could it possibly get that nasty??
Old 08-21-2004, 01:02 PM
Guest
4RUNR's Avatar
Blowback, and about 20 million cubic feet of air for every 100k on the road.
Old 08-21-2004, 05:21 PM
AUJWE
Guest
Posts: n/a
I cleaned the one on my family's 1990 4Runner for the first time at 185,XXX+ miles and it was pretty bad. Not as bad as the one in the picture above but nasty nonetheless.
Old 08-21-2004, 05:28 PM
Scofco's Avatar
Mine today:
Old 08-21-2004, 07:24 PM
Mine was pretty nasty - sludgy crap coming out - I know I barely touched that stuff. I'll have to go to NAPA over the week and get the necessary replacement parts to take the TB off.
Old 10-30-2007, 11:15 PM
slosurfer's Avatar
When the original motor blew on my work truck, that one was pretty bad. I'm glad I wasn't cleaning it.
Old 10-31-2007, 03:19 PM
2000t4r's Avatar
Good luck locating the TB gasket, I had no luck when I cleaned my TB a while ago. The stealership didn't even have one.
Old 10-31-2007, 03:33 PM
Greedy's Avatar
URD has em for like $5 or so and they are the "O" shaped ones..
Old 11-04-2007, 06:33 PM
TACOMANATOR's Avatar
You mean "blow by". Combustion gasses leak by the rings into the crankcase. The PCV system recirculates this "blow by" into the intake where it is reburned. This is what craps up your throttle body.
http://en.wikipedia.org/wiki/PCV_valve
Blamalam
03-12-2022 07:34 AM
Blamalam
08-16-2015 12:29 PM
mtc1105
08-04-2015 08:06 PM
bighaydn
08-04-2015 07:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: What was the worst throttle body you've ever seen?
