What octane are you running with advanced timing?
Old 08-09-2004, 10:44 AM
ChickenLover's Avatar
Like a lot of you, my timing is advanced 2*. Would it be beneficial for me to run a higher octane gas? I am running the cheap stuff right now (87 octane). Thanks.
Old 08-09-2004, 11:03 AM
AgRunner06's Avatar
You only need to run higher octane if you have pinging. I've got some pinging but I think it's more due to my crappy injectors. So I still run regular but I don't think my timing is quite 12* anymore. After the injector swap (if I ever get it all straightened out) I will probably bump the timing up a little more.
:bounce2:
Old 08-09-2004, 11:07 AM
I don't have any pinging, so I guess all is well. Thanks Agrunner.
Old 08-10-2004, 05:15 AM
gwhayduke's Avatar
When I checked mine earlier this summe it was 13 degrees BTDC. I wasn't getting any pinging, but I would get about 1 more MPG with premium. I reset the timing at 12BTDC and it's consistantly getting 19MPG on regular.
Old 08-10-2004, 08:05 AM
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
With the timing advanced in my '90 3.0, I would run 89 octane or higher if I was going to be towing. The rest of the time, I ran 87 (unless I would get some pinging from a crappy tank).
sonic concepts
07-01-2015 02:33 PM
ibayne
06-26-2015 06:30 AM
saphirekosmos
06-22-2015 10:26 AM
bobbybouche
06-18-2015 10:22 AM
2k-c
06-26-2002 04:24 AM
Quick Reply: What octane are you running with advanced timing?
