What Kind of floor jack do you use for front end???
Old 01-03-2004, 11:45 AM
swerks's Avatar
Question What Kind of floor jack do you use for front end???
I have been looking for a floor jack that would lift the front of my runner but nothing seems tall enough. what does every one use???
Old 01-03-2004, 11:55 AM
Bob_98SR5's Avatar
Swerks,
This is what I got:
http://www.sears.com/sr/javasr/produ...id=00950148000
Only lifts it up a few inches beyond the PP lift, but enough to make it more comfy working underneath.
Bob
Old 01-03-2004, 12:27 PM
Cebby's Avatar
I have an Autozone "special". Looks like Bob's but it's red.
Old 01-03-2004, 12:32 PM
swerks's Avatar
Im looking for something that will get my tires off the ground
Old 01-03-2004, 12:35 PM
MTL_4runner's Avatar
How about a nice set of jackstands to go with that floorjack idea.
Old 01-03-2004, 12:39 PM
swerks's Avatar
I have the jack stands, but I need to get the truck up so I can get them under there.
Old 01-03-2004, 01:00 PM
Guest
4RUNR's Avatar
Jack it by the control arms?
Old 01-03-2004, 01:02 PM
wimpywade94's Avatar
jack it with wood spacers on the jack? dont know how safe it is but thats how i got my 32'son my old truck when i was putting in the engine and stuff.
wade
Old 01-03-2004, 01:06 PM
Arnold's Avatar
Ditto.
Old 01-03-2004, 01:36 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Originally posted by Arnold
Ditto.
Double ditto.
That is how I always raise the front end, and put a jack stand under the control arm.
http://pnw4runners.com/tando/mod16.jpg
http://www.toyotaoffroad.net/tando/y...eel_change.jpg
Gets the tires all the way off the ground if you need to change one.
Old 01-03-2004, 02:09 PM
FirstToy's Avatar
Originally posted by Bob_98SR5
Swerks,
This is what I got:
Bob
I have that jack too. 2 pumps and it's at 22" or you can do like Corey under the suspension. I've done that with another smaller jack I have.
Old 01-03-2004, 02:37 PM
Spectre's Avatar
I am looking at getting the Craftsman 3 1/2 ton jack with the stands, chocks, pad, four way wheel spanner, and some other stuff for $100.00
but at sams club they have a Michelin 3 1/2 Ton Floor Jack for $59.27
Old 01-03-2004, 03:01 PM
Guest
Yoter's Avatar
I have a Larin 3.5 and its worked like a charm over the years. Lifts my rig even though its got its seven inches of lift on thirty fives. Oh and my highlift but that isnt a floor jack.
Old 01-03-2004, 03:58 PM
swerks's Avatar
I thought about using the control arm but was afraid I might bend something, but I guess I will give that a try. thanks
Old 01-03-2004, 04:04 PM
I assure you, you will not bend anything that way.
Old 01-03-2004, 08:03 PM
4Paws's Avatar
use a towmotor..it will pick up the front end 6-8 ft depending on the height of the boom!
Old 01-03-2004, 10:27 PM
yotafool's Avatar
i got one from costco the other day, its 3.5 ton and goes up to like 21"s, payed 70 i think
Old 01-03-2004, 10:31 PM
Plays_with_Toys's Avatar
wade
I'd never work underneath it like that...
I have the craftsman 3.5 ton like bob's. I love it. Got it for x-mas so I don't know the price.
I also use the control arm mount block as a jocking point, it gets the tires off the ground well enough.
Old 01-04-2004, 06:31 AM
Yoda's Avatar
Look at the lift ratings (tons) and the lift height. 21" to 23" are the highest ones I have seen. Sometimes they say for SUV's.
Old 01-04-2004, 06:36 AM
Swerks,
This is what I got:
Using this one as well. If I need a a bit more lift - use 2 2x12s pressure treated lumber nailed together as a riser underneath the jack stands and the jack. This is safe as the act as platforms underneath each piece and not perched above.
Andrew
Quick Reply: What Kind of floor jack do you use for front end???
