What engines?
Re: 20r head on newer block
Originally posted by toyota parts dude
you cant put a older style 20r or 22r head on a newer 22r block. when you put the pistons to top dead center so timing will be rite when you install the head. the domed part of the pistons will hit the head. the head will not even sit flat on the block there will be a 1/4 inch gap. the cumbstion chamber is totally different and that ruins the idea...
The 20R and early 22R have the domed pistons, late 22R's have the flat top piston.
No you can't put a late 22R head on a 20R or early 22R block, that's where the major head/piston interference comes in.
As for the early head onto the late block, it can be done, but you won't be using a toyota chain for the timing chain, and your chamber volume has increased a significant amount.
20r was in all pickups and the celica and corona until 1980, replaced by 22r in 1981
i believe some 22r engines were efi in '84, most of them started in 85 i think.
i'm pretty sure that a 20r head will work on a laser block if it is milled down to use the single roller chain. 20r head is superior to a 22r head because it uses a hemi design(a 20r is a hemi engine ), whereas the 22r has a swirl type combustion chamber
todd e you are right i just noticed that i goofed after you said that. thats what you get when you reply to a thread when you are really sleepy messing around on the computer. my bad hopefully you'll forgive me
#25
livelarg,
The 3.4 and the 3.0 use the same block (kind of like the 20r and 22r), so the transmissions will bolt up the same way ("drop in" swap).
toypartsdude,
No worries man
I've been known to do the same thing on more than one occasion.
Todd
toypartsdude,
No worries man
Todd
#26
quote:
Originally posted by Del
7mgte are 1st gen supra. The 3rd gen's are 2JZ... They make 330 hp stock.
Oh my bad, thought there were only 3 generations of Supras. Ok make that the 4th generation then.
1st gen supra - 1979(??) to 1982 (really that's a Celica Supra)
2nd gen supra - '82 (or close) to '86.5
3rd gen supra '86.5 - 92 7MGTE first used
4th gen supra - 92-98
To clear that up just a little bit.....
#30
Engines used by Toyota for U.S. minitrucks/4Runners from 1964 to present:
3RC - 1.9l OHV carbed 4-cylinder ('64-'69)
8RC - 1.8l SOHC carbed 4-cylinder ('70-'71)
18RC - 2.0l SOHC carbed 4-cylinder ('72-'74)
20R - 2.2l SOHC carbed 4 cylinder ('75-'80)
22R - 2.4l SOHC carbed 4-cylinder ('81-'90)
1L - 2.2l diesel 4-cylinder ('81-'83)
22RE - 2.4l SOHC EFI 4-cylinder ('84-'95)
2L - 2.4l diesel 4-cylinder ('84-'85)
2L-T - 2.4l turbodiesel 4-cylinder ('85-'86)
22RTE - 2.4l SOHC EFI turbocharged 4-cylinder ('86-'87)
3VZ-E - 3.0l SOHC EFI V6 ('88-'95)
5VZ-FE - 3.4l DOHC EFI V6 ('95.5-'04)
2RZ-FE - 2.4l DOHC EFI 4-cylinder ('95.5-'04)
3RZ-FE - 2.7l DOHC EFI 4-cylinder ('95.5-'04)
1GR-FE - 4.0l DOHC VVTi EFI V6 ('03-present)
2UZ-FE - 4.7l DOHC EFI V8 ('03-present)
2TR-FE - 2.7l DOHC EFI 4-cylinder ('05)
I'm looking for engine designations for Tundra, Sequoia, Highlander, and RAV4's. I know Tundras and Sequioas use engines listed above, but during what years?
#31
>>"I'm drawing a blank for the nomenclature for the new (2005+) 2.7l engine. Perhaps someone can fill this in."<<
Filled!
The '05 2.7L I4 is called the 2TR–FE engine;
The '05 4.0L V6 is called the 1GR–FE engine.
Filled!
#32
jeez...the RZ engine is out already, after only about 10 years
compare that to the R engine, which lasted more than 40.
then again, other countries will probably get the RZ motors still...
#33
Yeah, I suspect that the rest of the planet will continue to get RZ engines for years to come..
They should have labeled the new 2.7L, 3TR, instead of 2TR..
2TR-FE just doesn't sound right, IMHO.
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
