What is this box in my engine bay?
Old 11-27-2013, 10:36 AM
DubbleJ's's Avatar
Hey guys. This box makes an air noise (let's be honest, it sounds like a fart) every 5 seconds or so after I shut off my '96 Tacoma. If I pull off the circled line it stops. The line just goes down into the frame rail below and I cant follow it past that. What is this? Some sort of vacuum box?
I am trying to figure out why the truck is only blowing luke warm air out at best, I flushed the heater core and not much improvement. Wondering if this has anything to do with that...
96 Tacoma 2.7L 5spd
Thanks for any input!
Old 11-27-2013, 10:41 AM
wyoming9's Avatar
Red face
You really have no idea ??
It is your fuel Evap system in the old days looked more like a black coffee can.
charcoal canister!!
Nothing to do with your lack of heat.
Is the valve opening to allow the coolant flow ??
Old 11-27-2013, 10:50 AM
DubbleJ's's Avatar
Right...charcoal can. Why do you think its making an air noise every 5 secs after the truck is off?? Weve had this truck in the fam for years and I don't recall every hearing it before...
Old 11-27-2013, 11:01 AM
wyoming9's Avatar
Red face
Bleeding pressure off the tank.
Is the MIL light on?? Any Codes??
Maybe you just never took notice.
Had any work been done in the engine or gas tank areas ??? Perhaps got some lines on wrong?
Old 11-27-2013, 02:50 PM
akaphilly's Avatar
try blowing out the lines. 1 could be clogged.
Old 11-28-2013, 02:54 PM
DubbleJ's's Avatar
Light is not on, I replaced the starter a couple months back that's about all the recent engine work.
Ok will do. just disconnect them at both ends and blow air through?
I cant even see where the suspect line goes to...it just goes into the drivers frame rail. Ill try to have a better look tonight.
THanks!
Old 11-28-2013, 04:26 PM
totally a bro
Staff
vital22re's Avatar
the line is "vent to frame" that is all it does. The valve clicking noise you hear is normal. No codes, no problems.
As far as the heat goes, it could be someone kicked off one of the cables for the flaps in the heater system.
Old 12-01-2013, 08:58 AM
DubbleJ's's Avatar
THanks man. I blew air through the line and it still does it... weird, I don't remember hearing this ever before.
jerusry
10-19-2015 05:28 PM
msane99
07-17-2015 10:13 AM
crashburnoveride
07-10-2015 06:39 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: What is this box in my engine bay?
