| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Sponsoring Member
The weekend brought a new mod...
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#2 (permalink) |
You'll have to inform us less informed people on what the hell you're talking about...or maybe is it MI? I have no idea
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe. 1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe. |
#3 (permalink) |
i see the difference is the MI, but im not sure what is meant either, but im also really sick with a fever, so its probably blatantly obvious, and im just missing it...
#4 (permalink) |
Weeee! More ponies for you!
#5 (permalink) |
Sponsoring Member
MI = Methanol Injection.
You spray a mix of water/methanol into the intake in order to reduce the intake temperature. This allows you to run a denser fuel mixture at high RPM which lets you WAY advance the timing which nets you horsepower. I have tuning to do, but the early results are pretty impressive. I used to only be able to run about 1+ (relative) degrees of advance at WOT, this morning I was +15 without ping. Flooring it from 30mph will toss you back into the seat. This is the last mechanical step I want to take on my quest to pass 400hp at the crank. The rest now is tuning.
__________________
#6 (permalink) | |
Quote:
Sounds like some fun! So the stock 3.4L will actually stand up to 400hp?? I would think that would just tear it up. Oh, well all the more fun for you! Would NOS be as good and about the same price? Seems like they both add power, both have to be refilled, ect... And has anyone heard about CryO2 systems? They are used on some tuner cars. It used Co2 to cool the intake air down to near freezing (no it does not inject it into the intake, it is just used to cool it). It is a nice little mod people do down here in hot Texas, up north it doesn't do as much. |
#7 (permalink) |
Jeebus. Sounds crazy.
Where do I get one!?
__________________
#8 (permalink) | |||
Sponsoring Member
Quote:
Quote:
A couple of folks here have tried NOS in this engine... The block holds up, but the heads tend to come off. NOS is VERY nasty to an engine. It has to be built to be able to handle it - that usually means larger bolts on the heads, grommets around all the ports etc. Quote:
__________________
#9 (permalink) |
Sponsoring Member
Gimme your Visa and I'll order you up the parts.
![]() fwiw, this won't do anything on a NA engine. You'll need to be SC'd, and then run pretty large injectors, fuel/timing management etc. This also isn't applicable to TC'd engines - the equivalent there is an intercooler.
__________________
#10 (permalink) |
Yeah, Cry02 is a cool and not very expensive mod that actually works.
see: http://www.cryo2.com/products.asp?m=sc&cid=1 I have seen these on a few cars and even saw a guy on a dyno with it. It added about 10% - 20% on a 100 degree day (pretty common here). The cooler the day the less it helps but for the price it is an intresting mod. Plus it looks like a NOS tank ;-) |
#11 (permalink) | |
Quote:
Finally! Let me know when you are ready to dyno, I know of a place As a side note, I will have my truck ready this week, maybe we can schedule a session at the same time.... Gregg
__________________
- 1999 4Runner Highlander Edition - Turbonetics BB T3/TO4E TURBO - URD Fueling - 3 Inch Turboback Exhaust - 16x8 Volk TE37X - OME Lift |
#12 (permalink) |
Super Moderator-Sponsoring Member
Staff
Are you wheeling or drag racing?
When do you add the bling spinning 24s?
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#13 (permalink) |
Mark sweet. I might need to ask you some questions when I do my Modified STS turbo setup soon (peicing parts together with my bro to do a custom turbo setup) what was your last dyno result before the methanol?
#14 (permalink) | ||||
Sponsoring Member
Quote:
Quote:
I'm "improving the state of my daily driver such that I can have fun on and off the road".Quote:
Quote:
I'm working out a testing grid now, but it'll include a ton of combinations... SC, SC with ignition kicker, SC with kicker and MI, SC with just MI, SC with deckplate in/out.... etc. The only thing I can't really do is test with/without Johnny's cams (Weasy2k) or w/wo the Port & Polish.
__________________
#15 (permalink) | |
Quote:
__________________
#16 (permalink) |
Awesome,
Can't wait to see what you come up with... I might have to invest myself... Glad to see the Runner is still running Mark!
#17 (permalink) | |
Quote:
Before: WHAAAAAAAAAAAAAAAAAAAAAAAAA! WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA! WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA! WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA! After: WHAAAAAAAAAAA! WHAAAAAAAAAAAAAAAAAAA! WHAAAAAAAAAAAAAAAAAAAAAAAAAA! WHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA! Shhhhhweeeeet! We have been waiting for a long time to find out just how much your beast is stomping the ground with. |
#18 (permalink) |
Sponsoring Member
heh... me too.
![]() I had a scare a week ago. The engine flooded out after the SMT5 freaked out as the battery drained (that old problem). It was at a body shop, I'd left the dome light on, and they kept trying to start it. The SMT5 wasn't letting it spark, so the plugs basically got _drenched_ in fuel. It'd catch a couple of times, but that just spat raw fuel out the cylinders, and... ...that seeming trashed the O2 sensor. Once I got the truck running using the bypass for the SMT, I had to run it for a week without the piggyback until I could get an O2 sensor and find some time to reload and clear out the SMT. The truck ran like a P - I - G PIG, VERY rich. In fact (and here's the scare) it was running so rich that the EGTs were UP. Up to the point that I was tiptoeing around major issues waiting for me in the wings. EEEEEEEEEEEK! I finally pulled it together on Saturday, swapped the O2 sensor and got the SMT back online. The truck raw AWESOME. Then adding the spray yesterday... heh. ![]() Anyway... looks like Gregg and I will be on the dyno in about a month. Should be VERY entertaining!
__________________
#19 (permalink) |
Yesssss!
Have you figured out the closed loop fuel enrichment yet? I have not had a chance to tune with the MAP-ECU2 yet to tell if it will work or not so that is still a big question mark for me. I can't wait to see how your set-up preforms - actually a little scared - it will probably put my little turbo to shame
__________________
#20 (permalink) | ||
Sponsoring Member
Quote:
I don't think that the MAP-ECU2 will buy me anything right now, outside of consolidating boxes. If I tear this stuff out, I'll go full-hog. If I could get a straight answer about the MegaSquirt being able to support multiple channels of coil-on-plug ignition, I'd be all over it. Quote:
You know that strip of 124th that runs across the Wood/Red valley? Welcome to my morning test-runs.
__________________
#21 (permalink) |
Man Mark, I'm way jealous!
Really excited to see the Dyno sheets...
__________________
Brian 1998 4Runner SR5 |
#22 (permalink) |
sounds like some fun here. anyone have a 22re 4cyl tuned out like these?
__________________
Dead '94 2.4L 22re 2wd pu, k&n air filter, thrush glasspack, 4in over stock rear shackles, 1.5in ball joint spacers, 4in infinity reference dash speakers, pioneer head unit, 10in p2 sub, alpine amp. bed cap topper thingy. great for campin. Current-2004 toyota tacoma, 2wd, 3.4L, prerunner, e-locker, tow package, trd package, ext cab, alpine head unit, polk speakers all around, punch p2 10" run off a alpine mono amp, silver paint. ohhhh its purty... |
#23 (permalink) |
__________________
#24 (permalink) |
last and most important step is to dyno tune it or else things will be whack out.
post a dyno graph
__________________
Tran, oO 4runner - Millenium Silver WTB: 01-02 4runner right(pass.) taillight .,~??▼.,~??▼.,~??▼ WTB: Hood wind deflector |
#25 (permalink) | |
Quote:
__________________
| '97 4runner 5spd SR5 w/ Tan leather int. | Diff. Breather | Hella 500 Driving Lights | Alpine 9856 Headunit | Old Man Emu 3" lift from Toytec | Green Tokicko Shocks| 265/75/16 BFG A/T | SS Diff. Drop | Polk Audio db6501 components | Profile AP600 amp. | Alpine MRP-M1005 amp | 2 12" Alpine Type-r Subs |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| weekend of wheelin and mod-buyin! | lee | 95.5-2004 Tacomas & 96-2002 4Runners | 32 | 02-04-2006 05:19 AM |
| Had a mod-full weekend... | Marc P | Offroad Tech | 3 | 12-17-2005 04:54 PM |
| Did the Stereo Mod this weekend . . . | DrummerDaveB | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-23-2003 08:45 AM |
| A mod-ful weekend...just little stuff :) | Bob_98SR5 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 11-10-2002 01:23 PM |
