Want to increase range of factory alarm
I have a 2000 4runner Limited with the factory alarm. I wanted to add a remote start to it that will work with the factory remote, but the reception on the factory alarm is horrible. Anyone know any ways to boost the reception? It has always been like this ever since I got the truck three years ago.
thanks,
Neil Amar
thanks,
Neil Amar
neil,
i've tried to lengthen the grey antenna wire, but that hardly helped. i even tried attaching a wire to the diversity antenna to the grey antenna wire, but the results were less than thrilling. it extended the range by about 5x's. which is to say about 25 feet vs. 5 feet!
Anyways, my RS3000 is wwaaaaaaay worse than my former 99's RS3200. so if you have a 2000 w/ a RS3200, consider yourself lucky.
Bob
Bob
I'm not sure what kind of anteanna the factory alarm has but with my alarm in my accord I mounted a cell phone anteanna to the back window and soldered it to the anteanna. There was some impedance mismatching between the two but it did help with range. But I got the same range from soldered some 22 gauge onto the stock anteanna and running in up the side of the windshield. It's all about getting a better line of sight for the signal. It has a hard time going threw your doors and dash. I doubled the range by extending the anteanna. Good luck.
What is your range?
My 99 4-button Keyless entry (no alarm) will work to about 50ft or so. One easy thing to try is a different remote, as yours could be slightly out of tune. Remotes are cheaply available on Ebay, just do a search for 'hyq1512y'. Avalons, 4runners, sequoias, etc. used these remotes.
You would have to go through the programming procedure as described in your Service (not owner's) manual.
Originally posted by customcruiser
hold remote under chim and open mouth -- works better the more fillings you have
I hold my remote as high as I can. And got the biggest antenna I could. The truck body was in the way so I removed it. Then the engine was in the way. I removed it too. Transmission -- gone.
And this is what it looks like:
:cry:
:cry:
Originally posted by MTL_4runner
Funny how that actually works!
Originally posted by midiwall
Yeup, it works 'cause your body is turned into a passive radiator.... Basically your skeleton ends up "vibrating" at the same freq as the transmitter, and it handles the carrier modulation as well.
Passive radiator ... :pat:
vibrating ... no comment
That is one of the funnest things I have read in the last 4 minutes.
Good show!
Nothing like stray capacitance and frequency harmonics.
Good show!
Good show!
Holy smokes.......speak english!
Originally posted by pinoy
"Hey, did i turn my alarm on?" *walks back 5 feet and presses.* *Walks 5 yards and presses* *walks up to door* "Beep Beep." Yeah.. i thought i did.
First of all, what frequency range does the alarm use? You could try buying an FM booster from radioshack and wiring that into your alarm. It's meant to increase FM range with your radio, but it might do the trick. I think they cost around $30. It helped a bit with my old radio.
Hyperlite I bow in your awesome presence.
The Pringles can wireless antenna with a laptop running Linux.
Some would say "hack" but not me. I would say "X Gen shortwave transceiver" or "better than a soup can" 802.x.
Plus nice job in high lighting the UHF/VHF antenna.
LotOMiles
09-14-2015 11:45 PM
zz_denis
09-06-2015 03:43 PM
