w59 input shaft replacement ?
Old 08-26-2014, 07:28 AM
trx125's Avatar
Looks like I'm going to have to replace the input shaft on the transmission. What I would like to know is with the bearing cover in removed and the case seperated, can I remove the input shaft from the main shaft without having to disassemble the entire thing. Basically can I remove the input shaft from the main shaft, install a new bearing on the new input shaft and reassemble everything? Thanks.
MO transplant
04-23-2023 11:58 AM
mskalmus
05-28-2017 07:51 AM
A2theK
01-10-2016 10:18 AM
Iceman4193
07-15-2015 04:48 PM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: w59 input shaft replacement ?
