Used an Induction cleaner.. Idle now 400rpm higher
Old 02-03-2005, 01:00 PM
gummi's Avatar
Hi guys, (and girls )
I bought a 3 pack engine cleaner:
Induciton cleaner
Fuel system cleaner
Oil system cleaner
After using the induction cleaner.. the idle is now around 1000-1100 rpm/min instead of 750 before. (750 is the original idle).
I let the engine idle for a few minutes after the treatment, and then drove it a little to clean it out. it was still running higher..
Then I parked and pulled the ECU fuse for 5 minutes, started and let it idle for a while, then drove it a little.. still 1000-1100 rpm/min.
So I guess this rpm thing is permanent, and might be due to cleaner induction. What should I do..? is there a way to lower the idle rpm ?
The engine is 22-RE in a Toy Hilux '92, 276.000 km
Thanks !!
Old 02-06-2005, 01:00 AM
84sr5yoty's Avatar
This is a common issue after cleaning the throttle body. The idle is higher because you opened up some of the orfices that were previously plugged to a certain degree. There is a screw to adjust the idle located on the throttle body to the left of the intake hose. Turn the screw in (clockwise) to lower the idle.
Old 02-06-2005, 03:25 AM
shovelhead's Avatar
Dumb question but are you sure that you didn't disconnect a vacuum hose during the cleaning process?
Old 02-06-2005, 04:00 AM
gummi's Avatar
Yes I'm sure of that..
...just guess it had to adjust it self, and that indicates thad the cleaning was successful, but the idle is often rough, and I can notice a stubmle in the rythem of the engine, guess I will do another session sometime later, could also be normal, or some other problem, I went on a long trip yesterday and the truck worked well, but I can never maintain a 100 km/h speed in a strong headwind.. the torque could be better.
I have an exhaust header, 2,5" exhaust, no cat. K&N, 38" and 5,71 Diffs, ARB rear locker, A/C air compressor - tank etc..
you can find some good pics on our website: www.depill.tk
GrimWolf
08-28-2015 03:36 AM
tinigunner11
08-14-2015 01:19 PM
Cbr954ryder
07-25-2015 06:32 PM
Quick Reply: Used an Induction cleaner.. Idle now 400rpm higher
