Tundra Lift Top Plate Studs Help
Old 03-29-2007, 03:14 PM
barbakos's Avatar
I'm getting ready to do the tundra lift on my 2002 4unner but I have run into a problem. Maybe it's not even a problem. I bought some extended top plate studs from Wheelers so I could put on Bamachem's spacers. Well, I hammered out the stock studs as explained by Bamachem then the new studs just slipped into the top plates. There was no possibility to seat them, because they fit somewhat loosely in the top plate. They aren't real loose but I don't know if this is going to cause me problems down the road. Plus, when I try to put on my nylon lock nuts, the studs will just spin. Any help? Did I screw something up?
Old 03-29-2007, 03:22 PM
barbakos's Avatar
I have an aftermarket plate. Is that a problem? I haven't tried to put the old ones back in though.
Old 03-29-2007, 03:52 PM
barbakos's Avatar
scheisse
Well, I have aftermarket plates and the old studs still seat right in them. Am I right in thinking I need to use the oem plates that are still on the 4runner?
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: Tundra Lift Top Plate Studs Help
