Transmission Question
Old 03-09-2013, 04:11 PM
wormhole's Avatar
Look another tranmission question thread. :yo:
Question: What you cause the tranmission to hold 1st gear to long.
Reason behind the question, my 4runner seems to hold 1st gear somewhere past 30mph before final shifting into 2nd. In doing so it kind of vibrates abit then changes gears. The transmission shifts fine between 2nd, 3rd and 4th. It's only from 1st to 2nd does it do this.
Yes, I'm currently trying to weed though all the transmission threads on the site.
Vehicle 2002 toyota 4runner with 173,xxx miles
Old 03-09-2013, 05:02 PM
kball's Avatar
When the engine is cold it will hold the 2-3 shift until around 30-35. Once it warms up it will shift normally. It may feel like it's the 1-2 shift but if you pay close attention it's really the 2-3.
Is it holding the shift even when warm?
Old 03-10-2013, 08:58 PM
Adam F's Avatar
Yep, trans will shift at 2,750RPM from 2nd to 3rd when its around freezing temp
Old 03-11-2013, 10:07 AM
J2F42C's Avatar
It sounds like the solenoid. Change out all three from the solenoid kit that can be had on Ebay for less than $100.
chuckross1957
06-28-2019 10:19 PM
mskalmus
05-28-2017 07:51 AM
mYnAmEiSmUd
07-20-2015 06:48 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Transmission Question
