Transmission Cooler - Which one / best price??
Originally Posted by ElwayLite
I have a question about knowing if you have a cooler, does the tacoma have a cooler option, because my prerunner has an aditional smaller coil on the front of the radiator with two hoses heading out of it, I can't really tell where they go exactly so I dont know if it is a cooler or not
Also, if you dont do any real towing is the cooler still a smart idea for longevity or is it a waste.
Do you do any offroading or any other time that you may be spending a lot of time with high revs and a slow forward speed or "abnormal" load on the tranmission? For example, do you drive in snow/heat or other inclimate conditions 3-4 months out of the year? Is a lot of your driving time spent going up and down 3-5% (or more) grades?
If so, then it's a very worthwhile add-on.
I have a question about knowing if you have a cooler, does the tacoma have a cooler option, because my prerunner has an aditional smaller coil on the front of the radiator with two hoses heading out of it, I can't really tell where they go exactly so I dont know if it is a cooler or not, Also, if you dont do any real towing is the cooler still a smart idea for longevity or is it a waste.
thanks
thanks
Here's a little something for you to chew on:
-When your transmission fluid reaches 200 ° it starts breaking down.
-At 240 ° varnishes form and transmission life expectancy is cut in half.
-At 260 ° the transmissions internal seals and rubber parts harden and major damage starts.
-Above 295 ° you transmission start slipping, clutches burn out and carbon forms. With each 20 ° drop in operating temperature, your fluid and equipment life doubles.
Installing a cooler before damage starts and by reducing the transmission fluid temperature by as much as 60 ° can greatly extend the life of your transmission. Installing a transmission cooler can prevent transmission burnout.
......needless to say I have one on my truck too!
Thanks guys, it was the A/C cooling I was originally looking at, I got down there and traced the lines, looks like after the nerf bars are installed I'll be ordering a tranny cooler.
this_guy
08-10-2015 10:44 AM
FS[PacSouthWest]: 1988 4runner $1500
4x4-runner
08-03-2015 07:14 PM
