Towing 4runner cross country
Old 12-26-2008, 05:42 PM
b88miller's Avatar
Hi guys,
I'm looking at the possibiity of towning my '98 4runner, v6 automatic, across country within the next couple of months.
My question to you is this; if I use a tow dolly and tow the runner in a forward direction with the front wheels up on the dolly and the back tires on the ground and put the transfer case in neutral and the transmission in park will I be okay with the rear dirveline in place or should I remove it?
Thanks,
Brian
Old 12-26-2008, 05:43 PM
bigt's Avatar
REMOVE IT..only 8 bolts .. its ok if your going like 30minutes to an hour away but cross country not worth ruining your tranny!
i tow my 4runner with my hilux all the time on a dolly... its stick though... long trips i remove driveshaft
Old 12-26-2008, 05:55 PM
b88miller's Avatar
Understood, Thanks T.
Old 12-27-2008, 07:58 AM
Gerdo's Avatar
Remove the driveshaft. Parking brake off. Front wheels on the tow dolly.
Old 12-27-2008, 12:03 PM
b88miller's Avatar
Driveshaft comes out, thanks for all your help guys.
Brian
Old 12-31-2008, 05:27 PM
b88miller's Avatar
Alright guys,
If I pull the driveshag in preparation, will I be able to drive the vehicle up on the tow dolly in front wheel drive? Will I lose a ton of Tranny fluid from the back of the output shaft housing when I do that?
Thanks again,
Old 12-31-2008, 06:00 PM
bigt's Avatar
hrmmm you should be able to drive upon the tow dolly.. but if you keep it connected then drive on the dolly the truck will be JACKED UP so it would be easyier to get at the rear shaft...
you can just disconnect it from the rear diff and zip tie it up out of the way!
Old 12-31-2008, 06:38 PM
b88miller's Avatar
Thnks for the reply bigt, it's appreciated
Old 12-31-2008, 06:41 PM
Gerdo's Avatar
I would use some heavy wire to keep the driveshaft out of the way of the rearend. I wouldn't want to drop the DS on the road somewhere.
Old 12-31-2008, 06:46 PM
bigt's Avatar
zip ties.. the tie with wire then use some tape for backup!
BeMiceElf
10-10-2015 09:40 PM
09-04-2015 09:27 AM
hamburg99
07-13-2015 09:54 PM
rbh261
07-13-2015 12:04 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: Towing 4runner cross country
