Tow hitch question.
Old Mar 24, 2004 | 12:26 PM
pigcake's Avatar
Tow hitch question.
I've seen tow hitches hooked to tacos two different ways. One is just a hitch ball stuck into the hole in the bumper and then the other way where it comes up from underneath the bumper. Is one way better than the other? Right or wrong?
Old Mar 24, 2004 | 12:32 PM
WolfpackTLC's Avatar
Bumper mounts aren't as strong as true frame mounted hitches. So... the bumper mount is better for your departure angle and the frame mount is better for overall towing. Which ever one you already have is better for your wallet.
Old Mar 24, 2004 | 02:03 PM
MCE's Avatar
MCE
The bumper hitch is probably rated to about 2000# max, maybe less. The frame mount hitch should be rated to the full manufacturers rating (model/year dependent) assuming it came from the factory or is from a reputable aftermarket hitch supplier. For instance the quad cab taco is rated for 5000#.
If the hitch is from the dealer there might be a sticker on it somewhere with the rating.
Chicken12
Oct 14, 2015 03:54 PM
Brodetski
Sep 30, 2015 11:50 PM
Cycles
Sep 29, 2015 06:37 AM
Odin
Sep 26, 2015 06:56 PM
mirabile4runner
Sep 3, 2015 07:15 AM
