Torque settings...???
Old 03-15-2003, 02:43 PM
Bumpin' Yota's Avatar
Question Torque settings...???
Well I just swapped my stock, rubber, ultra-cushy bushings out for some taller polyurethane versions. However I do have one slight problem.....what do I torque the nut down to on the sway bar connect? The only thing I did was swap the bushings. I tightened to what felt about right, but I'd like to know the exact ft.lb. if anyone knows off hand... (this is on the front end btw)
4Runner, 1990, IFS, 4x4, 3.0L
Thanks,
Steve
Old 03-15-2003, 03:04 PM
zedex's Avatar
I think you tighten till it squishes the bushing a bit. Not much. Just a slight squish.
Old 03-15-2003, 06:06 PM
jalaber's Avatar
Here are the third gen specs, may give you an approximate idea...
Sway bar bushing bolts...14 Ft./Lbs.
End Link upper nuts........14 Ft./Lbs.
End Link lower nuts.........51 Ft./Lbs.
Old 03-15-2003, 06:14 PM
Im kind of weak on my terminology....got any diagrams of what each of those are? My front bushings only have 1 bolt that runs through a sleeve, 5 washers, and them and a single nut screws to the bottom of that bolt on the underside of the lower control arm. I take it that nut needs 14ft lbs or so....right now id guess it was closer to about 25-35ftlbs to get the squishyness that zedex described...
Old 03-15-2003, 06:44 PM
rabidbeaverbaby's Avatar
this might help...its from my 92 FSM....if its the wrong part lte me know i will scan something else (I scanned the whole page but it was too big)
Old 03-15-2003, 06:46 PM
Yeah thats for the shocks. I just swapped the bushings in my anti sway bar. And was wondering on the torque on them...
Old 03-15-2003, 06:48 PM
sorry for some reason i got confused .....is the anti-sway bar also called the stabilizer bar???
Old 03-15-2003, 06:51 PM
Thats a definate possibility...lol Have any specs on that?
Old 03-15-2003, 06:53 PM
yea give me a sec so i can mess around with my manual and the scanner
Old 03-15-2003, 07:02 PM
what's ypur e-mail address so i can just e-mail you the picks cause they are too big to attach
Old 03-15-2003, 07:04 PM
bumpinyota@aol.com
nelson390@hotmail.com
steve390@ufl.edu
dnelson391@hotmail.com
in that order too.... thanks I really appreciate it
Old 03-15-2003, 07:16 PM
sent it....let me know if it worked out and if it was the right info or if i am just a retard:cry:
Old 03-15-2003, 07:26 PM
You NAILED it! 19ftlbs of torque is the factory specification for the "stabilizer bar link nut." Eek what a name....
The difference with the polyurethane bushings is interesting, if im not feeling the placebo effect, I think I really like this mod....
Old 03-15-2003, 07:27 PM
how much did the bushings cost and where did ya get em
Old 03-15-2003, 07:30 PM
10 bucks and i got them at an AutoZone. They are the polyurethane "cushions" (as toyota calls em.) You get 8 for 10 bux and 16 new "retaining washers."
steve
Old 03-15-2003, 07:31 PM
sweet thanks!
Old 03-15-2003, 07:46 PM
jalaber's Avatar
A little late but here is the FSM page for the rear of a 1999.
Link
Kamaloha
10-16-2015 05:13 PM
JUICE222
10-13-2015 08:50 AM
bigtoy83
10-03-2015 06:09 AM
sonorn67
09-19-2015 05:39 PM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: Torque settings...???
