too lean
Old 05-12-2007, 04:43 PM
woody2474's Avatar
too lean
http://www.obd-codes.com/trouble_cod...gen-sensor.php
I took my MAF sensor off and cleaned it with carberutor cleaner. I also changed my plugs and my fuel filter, PCV valve and I still get a check engine light.
The MAF sensor reads: 27k ohm @ room temp.
The book says it should read: 2-3k ohm@ room temp.
My information comes from the Haynes Manual. Could the 27K be ok or should I replace it?
Old 05-12-2007, 05:18 PM
OSU4Runner's Avatar
Well if its out by 26k, I'd go ahead and change it. Don't cheap out on parts, get an OEM MAF. If it doesn't fix it, you can always just return it.
JonG85
01-18-2023 04:31 PM
Ditch Doc
10-27-2015 03:20 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
the_supernerd
10-01-2015 09:20 PM
Draven023
09-26-2015 12:41 PM
Quick Reply: too lean
