Tjm-17
Steve Schaefer sells them. He'll get it delivered to you for basically his cost. He'll also make you a set of hoops (scroll down to see hoops) that IMHO look better than any other hoops, if that's what you want. I don't like hoops on my rig, personally. That's why I got the T-17. If you do want hoops, get them put on by Steve on the way to you, or make sure that he'll do it later.
The T-17 is sturdy enough that all they had to do was drill/cut some holes for the winch to mount on and viola, a winch mount.
You'll need a winch w/o the integrated solenoid if you want to mount on any TJM. I just drilled a couple of holes in the top of my T-17 and mounted the solenoid/control box there. Amazon has roller fairlead covers that sort-of work for the winter assault (a-salt :-)) of MagChlor or whatever your local highway department uses. You have to run your hook up into the fairlead and fold it over at just the right spot in order for the cover to fit. It should keep some of that road grime out of my cable and the rest of my winch fairly well.
To mount a winch in the T-17, you have to get the bolts tightened that hold the bar on to the brackets before you can start the bolts that hold the winch. Otherwise the winch is in the way of starting or tightening the nuts that hold the bar on the mount brackets.
HTH.
EDIT: If you do use the Warn M8000 with a roller fairlead, you have to clock the clutch control lever two bolts = 72 degrees (ten bolts = 36 degrees / bolt). This makes the control lever hit the back of the opening for it when freespooling, but it works fine.
IF you get a roller fairlead w/ the M8000, you'll also have to grind out a little of the cable opening, otherwise, with a full spool, the cable will grind on the bottom lip of the cable opening. Not sure about a Hawse fairlead. Probably works better w/o modifying the bar.
HTH.
i got mine from steve at sonoran steel. i paid 130 for shipping. its $30 cheaper if you can have it shipped to a "comercial" address. i wish i would have done it because i went and picked it up myself. after he sent me the tracking info, i called the place and told them i would come and pick it up at there warehouse. they just use a standard shipping company so it wont be a problem for you to pick it up...lesson learned!!! i pm'd you the p[ricing info.
awesome, what exactly constitutes a commmercial address.
Also is there anywhere to get clear bumper lights, if not I can just tint them black.
#25
I also work there though, i wouldnt try it yourself inless you work at a business
#28
just have it shipped anywhere. when you get the tracking number, it has a link to the website and you can call them and have them hold it at the terminal for pick up.
ill dig through the emails and see if i can find the number....
EDIT:
deleted it already, sorry. pm steve and maybe he has the # for the place that ship the bumpers for tjm
EDIT:
#29
Twisty the Aussie has a TJM and modified some tacoma clears to fit
http://www.boosted4runner.com you can pm him i forgot all the details he also added fog lights to his looks like a super claean install.
Aaron
Aaron
#30
i want that one so bad.
fireteacher
14
09-28-2006 02:32 PM
