Tire size help
Old 04-23-2011, 09:07 AM
frohbego's Avatar
Tire size help
I have the Sonoran Steel System 7.2 Suspension on my 2002 4Runner -
About: 2.5" Front & 3" Rear.
http://www.sonoransteel.com/index.ph...&products_id=4
I currently have on the BFGoodrich All-Terrain T/A KO Tires 265/75R16.
My question is can i go up to the next size BFGoodrich Mud-Terrain T/A KM 255/85/16?
Will they fit without any rubbing? I live in PA and wheel spacers are illegal. I have attached a few photos with my current tires.
With 255/85/16 tires can i get away without re-gearing?
Some photos of my current tires and the space i have right now -
http://4.bp.blogspot.com/-LwMrytalKi...NER-tires1.JPG
http://1.bp.blogspot.com/-dStLvnf8oU...NER-tires2.JPG
http://2.bp.blogspot.com/-IUYh7ILp7Q...NER-tires3.JPG
Thanks!
- JON
Old 04-23-2011, 09:50 AM
sleeper2002's Avatar
I don't think you'll run into issues going taller, i just wouldn't go any wider. I put a 3''front 3''rear Tuffcountry suspension lift on my 2002 tacoma and they said that I would have no problems running 32'' tires. I'm running 265-75R 16 BFG mud terrain t/a's on it now and i can definatly see going with a larger tire next time. As for regearing it, i would leave that alone unless you go with something crazy like 37''ers; you will notice a slight power loss, but not nearly enough to warrent regearing it unless you want to go crawling. Hope this helps!
Old 04-24-2011, 11:22 AM
frohbego's Avatar
Can anyone post photos of 255/85/16 on their 4runner?
Thanks!
djpg2000
11-11-2020 04:56 AM
jgallo1
10-26-2015 06:39 PM
Gravel Maker
RuffStuff
08-06-2015 04:27 PM
Luvmeye22re
08-04-2015 03:53 PM
coffey50
07-28-2015 10:55 AM
Quick Reply: Tire size help
