Tire question: Is rubbing bad?
I plan on gettin 265/75/16 bfg a/t's in a couple days, and I have the factory sr5 black middle size flares, I know they'll rub on turns, but when rubbing, does it cut down A LOT of tread life? or just a little? Or not at all? And does it hurt the tire?
Also I have oem running boards on now, I"m getting them taken off tommorrow, if I had them on with the tires, will they cause in extra rubbing? Or am I just taking them off for no reason.
Thanks!
Thanks!
Get a body lift and you won't have to worry about any Runbbing! I dont know to what extent you'll rub with that set up but rubbing tires that I have seen do far more damage to your truck than to the tires. If they only rub when you've got the wheels fully cranked like parking or wheeling I wouldn't think that would kill your tire life much. Now if you rub when going at highway speeds that unsafe because that would eventually cause a failure of something. Sure other's will chime in that are 3rd Gen owners
UK
UK
Like UKMyers said, if it just rubs at full lock, not too much to worry about.
if it bottoms and hits your fender, you've got serious body damage waiting to happen.
I destroyed my front fender lip with larger tires because I was hitting them when I went over larger bumps at speed. A torsion bar adjustment helped that, but a body lift - even 1" - works wonders
Hopw this helps,
Todd
Hopw this helps,
Todd
Are you sure the 265/75's will rub? 265/70 was an option from Toyota with 16" rims, I just can't see that extra 5% making the difference in rubbing or not.
If you like the running boards, I say keep 'em on until you're sure that they will cause a problem. They come off easily, and there's a write-up in the tech section for it too. But taking them off will give you an instant lifted appearance.
Well I plan on going wheeling a few times, so would it be better to just take the running boards off? Cuz I have an appointment tommorrow, and I've been trying to get them off, but now that I'm about to get them off, I'm starting to realize a lot of other runners with them on and how good they look. Ahh i don't know what to do!!
Appointment: means 30 bucks to get them off at the dealership cuz I tried myself and the bolts wouldn't even budge. Should I cancel the appointment and just keep on attempting it myself? And what is this penetrating oil that's in the write-up mertzr? I tried wd-40 but that didn't really help.
Thanks.
Thanks.
you will not rub with 265/75r16 size tires. I have the same fender flares as you and 265/75's and there is absolutely no rubbing. i would definetly not pay the dealer to remove your running boards, took me about ten minutes to do myself.
Are you sure? Cuz if so then I"m gonna cancel my appointment. Hopefully when I get to discount tire they won't not install the tires cuz they won't fit or something will they? That's what I'm afraid of if I leave my running boards on when I get my tires put on.
so.......ARE YOU SURE?
I mentioned earlier that 265/70/16 was an optional size available from Toyota. So there are no issues at all with that size.
The only difference between the 265/70 and 265/75 is that you're gaining 1/2 inch in the sidewall (1 inch larger in diameter).
I can't imagine there being issues with rubbing and the running boards.
However, if you're planning on wheeling at all, you're better off with the boards off. They offer minimal protection and rob you of a bit of clearance.
Bottom line is that its your decision. In the unlikely chance that there is some issue with the running boards, I bet if just run out and show them the 6 bolts, they could just run them off for you with their air tools. I'd recommend removing the boards, but for reasons other the 265's.
Oh and BTW if WD-40 isn't working, then try a product called PB Blaster. Its at most auto parts stores and its in the same general auto chemicals area.
Re: Tire question: Is rubbing bad?
Thanks!
Thanks!
ok thanks mertztr, goat, and keisur
Hopefully that PB blaster will be strong enough to loosen the bolts. Cuz I already cut my hand on the underside tryin to get them off, only managed to get one. :cry:
After everybody's replies, I think I'm gonna cancel my appointment, and get the tires put on on wednesday and see how it goes.
Thank you everybody for the replies, now I'm not really worried anymore. That's what I like about this forum and not the other ones. Thanks again!!!
Originally posted by keisur
While at "dickscount" tire, make sure they use the haweka adapter to balance your new rubbers!! {assuming you have the alloy wheels since they are lug-centric}. they never could balance mine and they ruined them!!! after reading Gadgets vibration write-up, I never will ever go back to those turd burglars ever again!!!!!
Originally posted by NCSU-4runner
get a breaker bar for your ratchet, its not that expensive and you will DEFINETLY need it if you plan on doing more mods to your truck. the bolts will come off without hesitation then
Dude, they are gonna rub. I have the same size, and a 2.25" lift in the front and they still rub.
And yeah, loose the running boards. They are for women who need help getting in the runner. That was one of the best things I ever did.
Hit me up if you need help. I can get those suckers off.
Dan
Dan
Dan
Dan
