timing test jumper?
Old Oct 1, 2004 | 01:13 PM
jay-q's Avatar
timing test jumper?
i was reading the writeup done to adjust the tps on the 3.0 and it states
" to check whether the adjustment was successful start the engine and insert the timing test jumper, if the idle speed decreases audibly it is working normally"
well before i mess with the tps, i want to do this test and see what my engine is doing. only thing is i don't know what a timing test jumper is. please advise. where would i be able to get one and where does it plug into?
thanks
JQ
Old Oct 1, 2004 | 02:44 PM
eric-the-red's Avatar
thanks
JQ
I'm sure Toyota has a special tool for this but I just use a small piece of wire, about 20 guage or so. It jumps 2 connectors in the diagnostic connector box. I can't remember off hand which ones they are, something like TE1 and E, but I'm sure someone else will answer.
Old Oct 1, 2004 | 03:54 PM
evilcow's Avatar
Yup, Te1 and E1
Old Oct 1, 2004 | 06:31 PM
nunsa's Avatar
thanks
JQ
Greetings,
Under the hood next to ye olde fuse box is a grey diagnostic box, take a paperclip and insert one end into "te" & the other end into "e1", if the idle decreases your tps is working fine, if not your tps is shot or out of adj.
Good Luck!
A2theK
Jul 12, 2015 10:46 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
