timing off by HALF tooth?
1989 Toyota 4x4 truck with 22RE engine.
How could my timing be off by HALF a tooth? I thought that it would have to be off by at least one whole tooth.
Glenn
Glenn
Re: timing off by HALF tooth?
Glenn
Glenn
top gear allows cam to rotate at different speed of the engine. if just the top gear got jumped by one tooth, it would set the bottom off by half a tooth. at least it makes sence to me.
Re: Re: timing off by HALF tooth?
Originally posted by <96 Runner>
I guess it could be off by half a tooth if the belt was "tooth to tooth" with the other teeth. But there's no way that would happen.
Glenn
1/2 tooth normal
i replaced a couple timing chain kits for people and the new kit was off half a tooth. my personal truck is like that to. when you put the crack mark at o degrees the cam mark is 1/2 tooth towrad pass. side rite? if it is you have nothing to worry about .
