Timing Belt Etc...
Old 08-23-2007, 07:01 PM
toyo4runner's Avatar
Timing Belt Etc...
Hey i was just wondering about 2 years ago my timing belt came off and it happen because one of my tensioners was wobbling, i fix it but just out of blues does it hurt your engine if your timing belt tear off while your driving?
thanks and sorry for the stupid question!
Old 08-23-2007, 07:17 PM
fillsrunner4's Avatar
No i really dont think that belt could harm much in were its at.
Old 08-23-2007, 10:17 PM
pennywize's Avatar
depends on what engine you have...
Old 08-24-2007, 01:59 PM
Adam F's Avatar
He has a 2000 4Runner, that would make it either the 3rzfe or 5vzfe. (he mentioned a belt, that would indicate the 5vzfe) Both are non interference engines. On an interference engine, if you break the timing belt/chain, there is a chance that the valves will "interfere" with the pistons. Basically the valve will smash into the pistons, breaking or bending the valves, and denting/chipping or even shattering the pistons. On non-interference engines there is sufficient clearance between the valves and the pistons so you don't have to worry about contact.
Not a stupid question at all. It's something that EVERYONE needs to know about their vehicles. The 22re is an interference engine, and can/will cause major damage if the chain breaks. 3vze is non-interference. I don't know about the newer generation motors.
Old 08-26-2007, 05:41 AM
Wow i did do this a while back, i was driving and all of a sudden it just stop! The stupid thing is when i opend the hood i didn't check the belt, all i didn't was check battery connection and then i tired to jump start it like 3 times and it didn't start so then i finally saw that my belt was all torned up towed the car to my house and then fixed it, i cost about almost $500.00 for all new toyota parts, belt, water pump (gotta say the water pump bented) 2 tensioner and then it was all set. but after i replaced everything no nocking nothing, gotta say i was lucky to have a non interference engine
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Timing Belt Etc...
