TIE rod
Old 07-07-2004, 06:40 PM
Localmotion's Avatar
TIE rod
I have a 1996 4runner SR5. I was recently informed by toyota that i need my tie rod replaced. They quoted me 400 to do the job. I also found out the the tie rod itself was only 180. Does anyone know how to replace a tie rod and how difficult it is. I would imagine that it isnt too bad.
Old 07-07-2004, 06:48 PM
jimbo74's Avatar
what part? or the whole thing?! tierods are normally only like $40 and its the ends that normally break down......
Old 07-07-2004, 06:51 PM
the guy at the dealership told me the tie rod had too much play in it. I assumed that it was the whole thing. Maybe im getting screwed in the by the dealership.
Old 07-07-2004, 06:55 PM
jimbo74's Avatar
there are inner and outer left and right tie rod ends
Old 07-07-2004, 07:09 PM
Oh ok. hmm...is there anyway i can check myself which one i need to replace? WHat do i need to look for?
Old 07-07-2004, 07:26 PM
jimbo74's Avatar
you can chrck it, but its hard to describe what to look for... first determine what side the play is from... then look at the tireods and see which one moves without the assembly moving
Old 07-07-2004, 07:50 PM
alright thanks a lot for your help Jima.
Old 07-08-2004, 09:08 AM
Flamedx4's Avatar
If it isn't so bad you can clearly see it, get someone to turn the wheel back and forth, while pressing your finger into the rubber boot on each tie rod end. You can feel play that you sometimes can't see. A good one feels tight, and bad one has a clunk or wiggle to it. You'll know it when you feel it. Get a puller for about 10 bucks and a tie rod end for $20-$30 (from the auto parts store, not the dealer) and replace it yourself. The trick is getting it adjusted properly when you're done.
Old 07-08-2004, 06:33 PM
Awesome. Thanks a lot flame. I actually got someone from the Va Ttora club to help me out in a couple of weeks. Thanks for the help guys!
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
primordialbeast117
12-19-2015 12:23 PM
JookUpVandetti
09-30-2015 08:58 AM
beltcutter
09-30-2015 06:14 AM
Quick Reply: TIE rod
