throttle position using OBD reader/BR-3?
Old 12-28-2003, 11:48 PM
3.4Runner's Avatar
Just got a BR-3 reader after reading tons of rave reviews. Have a question about the throttle position % indicator.
I recently cleaned my throttle body and want to make sure that I didn't screw up the throttle cable positioning.
At rest, the throttle position reads 10.6%
With the accelerator fully depressed it reads 74.5% (74.9% when I really mash on the gas pedal).
Just wondering if these values are where they are supposed to be (Do I need to adjust the throttle cable position?)
Are you guys with the BR-3 (or other OBD reader) getting the same (or similar) readings? Can you post what numbers you get?
Old 12-29-2003, 12:07 AM
midiwall's Avatar
You're fine dude... Mine reads the same.
Those numbers are basically coming from the voltage that the ECU is picking up from the sensor.
Welcome to the BR-2/BR-3 club!
Old 12-29-2003, 06:22 PM
MTL_4runner's Avatar
Yep, it is working fine......no worries!
Williamemslie
14
10-05-2015 09:28 AM
JHalcyonM
09-14-2015 01:10 AM
zz_denis
09-06-2015 03:43 PM
larrys93pickup
09-06-2015 06:37 AM
seab1209
09-03-2015 05:41 PM
Quick Reply: throttle position using OBD reader/BR-3?
