throttle position = 8% at idle, normal?
Old Feb 14, 2008 | 06:36 AM
jrock's Avatar
according to my OBD scan tool, my throttle position is 8% at idle...not going into OPEN LOOP at WOT. Should it be 8%? I have heard I may need a new TPS sensor or adjustment to the throttle cable. 98, s/c, 5spd, 3.4L.
how do you know if the throttle cable is tight enough or not?
thanks in advance yall!
Old Feb 14, 2008 | 06:52 AM
eric-the-red's Avatar
Don't know about the % opening but I've always adjusted the cable so there is as little slack as possible. Adjust it with the engine off, tighten until the throttle moves slightly then back off a bit. Not very scientific I know but you just have to get a feel for it.
Old Feb 14, 2008 | 09:10 AM
jrock's Avatar
ok ill try that...thanks!
Old Feb 14, 2008 | 05:16 PM
MTL_4runner's Avatar
This thread might help you out a bit:
http://www.ultimateyota.com/index.ph...6&topic=1877.0
Old Feb 15, 2008 | 05:50 AM
seaofnames's Avatar
Mine I think was at about 9% at idle. My engine is pretty much stock though, the S/C may be making a difference.
Like the thread Jamie posted from ultimateyota, pull the positive battery terminal for 10 minutes so it resets the ECU, then fire up your scan tool and give it a go!
Old Feb 16, 2008 | 12:28 PM
hopper's Avatar
I run at 8% and 9%. Before I got the water pump/ timing belt replace I was at 8% after im at 9% intil I tap the gas pedal then it goes back down to 8%.
Old Feb 16, 2008 | 02:04 PM
mikes19984x4's Avatar
some of you might remember me askin about my rev limit problem on my 3.4, but could not going into open loop cause a my motor to "cut-out" at 4k rpms?
Old Feb 16, 2008 | 05:43 PM
Firecaptain's Avatar
I've got one of those scan tool / mileage computer combos, and mine is at 11%. Thougt it might be the device so I put it on the Ford Taurus and it read 0% at idle which to me made more sence since there was no throttle being applied.
My idle at operating temperature is 750rpm, engine is stock, 17.5mpg and it runs fine
but that 11% on the Runner has bugged me, guess I'll do some reading and stay tuned here to see if I can get it adjusted down.
montanatruck
Feb 26, 2017 07:07 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
jetpilot
Aug 15, 2015 06:48 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
smiley52
Jul 11, 2015 05:16 AM
