Thinking of Cornfed 3 inch
Old Jan 20, 2006 | 11:42 AM
98runn'n's Avatar
Talking Thinking of Cornfed 3 inch
I want to lift my 1998 4runner around 3 inches. I dont want to spend an arm and leg to do so. Cornfed looks like a pretty good route as far as spacers go. I understand that I will need a differential drop kit to give relief to my CV joints. What kind of ride can I expect from the spacer lift? How is the longevity of this route as far as maintenance goes and future problems associated? Any other recomenedations? Thank you.
Old Jan 20, 2006 | 11:59 AM
Localmotion's Avatar
search for the TUNDRA lift
4x4fink had a simliar idea but hated it
Bamachems lift is tried and proven
Go with the Tundra/OME
https://www.yotatech.com/forums/show...ghlight=Tundra
Old Jan 20, 2006 | 01:37 PM
BajaRunner's Avatar
If yourl looking for something cheap, go for Revtec or something... I think its 3".
I personally would stick to 2" suspension lift and 1-2" body lift though.
Its pretty rough with 3" spacers.
Old Jan 21, 2006 | 01:22 PM
grimpy's Avatar
I'm pretty sure fink's problem was that he had the longer coils to begin with, then with the 3" spacers, it was alot higher... Just to be on the safe side, stick to a 2.5" spacer with the diff drop... CV angles should be fine after.
Old Jan 21, 2006 | 01:29 PM
amorphous's Avatar
before you lift....read this:
http://www.sonoransteel.com/recommend.html
wise words.
Old Jan 21, 2006 | 02:55 PM
Brad's Avatar
Also check out ToyTec lifts. Their website is www.toyteclifts.com. An excellent alternative similar to Revtek and Cornfed and a little cheaper. Doug, the president is super nice and the customer service is excellent.
Old Jan 22, 2006 | 07:07 PM
HarrisonP's Avatar
I have the 3" cornfeds up front and went through the same problems as fink, I have torn countless CV boots. The 3" was way too much for my cv's with the diff drop. It is fine now, but I have a winch and TJM up front bringing the front down a little bit.
Old Jan 22, 2006 | 08:03 PM
BajaRunner's Avatar
I ran OME 881s, 2.5" cornfeds and 10mm trim packers for about 8 months and 15k miles and never tore a CV boot, but the ride was kinda stiff
Old Jan 24, 2006 | 04:31 AM
Judd's Avatar
I'm planning on running a 2" spacer lift and a 1" body lift to keep some of the stress off of the cv's. Just a thought, I cannot afford the OME/Tundra lift right now
Old Jan 24, 2006 | 04:35 AM
amorphous's Avatar
you should be fine then, just make sure you do the dif drop....and start saving for front end problems that will crop up (cv's, whole difs, etc, et al, ad nauseum!)
aaron
coffey50
Jul 28, 2015 10:55 AM
terminator
Jul 27, 2015 07:13 PM
colasurdo
Jul 17, 2015 11:29 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
