tapping noise/1998 tacoma V6
changed my timing belt,watter pump,cam seals,crank seal,and tensioner.When the belt broke it started making a tapping noise.Got it timed perfect and it is still making the noise>Has anybody had this problem,or know where I should start checking??????????
Well you should first try to see where the noise is coming from, see if you can come up with some conditions in which the noise operates and especially if it increases with RPM.
Did a piece of the belt stay inside the cover, possibly swingin' aruond and around?
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
12-29-2015 12:44 PM
bryan34w
12
09-30-2015 02:50 PM
