Tacoma Rear Leaf Spring Problem
Old Jun 4, 2005 | 08:38 AM
Rivalred's Avatar
Not sure if I posted it in the right section or not, https://www.yotatech.com/forums/showthread.php?t=60477
Any thoughts or comments would be appreciated....
Old Jun 4, 2005 | 09:13 AM
rugerm44's Avatar
springs
If you want to locate the problem quick spray wd 40 on the bushings.If it stops there is your problem.If not the spray the springs down themselves sometimes there is friction between them that can cause a noise.That way if you take it back you know what to tell mechanic. My dont make noise they just sag with only 18,000 miles on it.Man the springs are weak on these things.All I did was put a topper on it and later it droped 13/4 inches.I put a set of airlift air bags on it and solved the whole problem.I have a 700lb 4 atv.I put it in the back of my2004 tacoma.The fenders were with in an inch of the tires.I thought it was a truck not an suv.oh well.Make them put new springs on it.Toyota can afford it.
Old Jun 4, 2005 | 12:03 PM
CynicX's Avatar
oddly enough...My old boss at a company I used to work for has a 97 Taco and he was getting some squeaking in the rear leave. It was driving him nuts and he couldnt find where it was coming from.
He talked to a mechanic friend and he told him the problem and the mechanic went down a long list of things it could be. The mechanic asked him what kind of vehicle it was and when my boss told him it was a Taco the mechanic said it was probably a cracked spring. Sure enough we crawled under it and saw a hair line crack in the pass side leaf. We got a junk yard replacment and there was no more squeak.
Now the thing that confuses me is, has this mechanic seen alot of failed Taco leafs to assume that was his problem? I havent talked to the mechanic since, then I moved away and ended buying a Taco after the fact so it would be goofy for me to call him now.
Dont think it could be something similar do you? Its unlikely but its the best I can help from my experiences with squeaks.
Check your lemon laws in your state and keep taking it back until it qualifies. Then buy an 06 which will hopefully have the problem solves. Seems extreme yes but I'm pretty sure you paid a pretty penny to have this vehicle parked out in front of your house and you deserve to have it operating properly. Besides its embarrassing to have a new vehicle rolling around making odd noises.
Old Jun 4, 2005 | 12:19 PM
P. Bauer's Avatar
Spray the entire leaf spring pack with WD-40...
the leafs are probably rubbing, same thing happened in my 2002 Tacoma after a river crossing.....
worked for me, but I used lithium grease spray. YMMV.
Old Jun 4, 2005 | 01:59 PM
EnolaGaia's Avatar
First - you're not the only one who's been driven 'nuts' by squeaking rear leafs on an '05. Not all '05 owners are reporting this problem, but those that do are having a hard time getting it resolved...
One prominent victim has been CustomTacos member 'KAuss', whose XR rear leafs have driven him up the wall. Multiple trips to the dealership have not permanently fixed the noise (though he's gotten temporary relief now and then).
No one has yet come up with a definitive explanation. Some of the theories (including those rendered by the dealer) include:
- bad leafs (though I don't know that anyone's proven a crack yet)
- bad bushings
- composite bed (i.e., it's the bed, not the spring, that's creaking)
- improperly torqued bolts somewhere under there
- the noise is actually the separate 'under the cab' (cab mounting bolts) issue, and only *seems* to be coming from the rear leafs
Old Jun 4, 2005 | 10:12 PM
Rivalred's Avatar
- bad bushings
The noise are the springs.... I just do not know if it is the shackle/bushings/or springs....
If they dealer can not fix it... Fock it, I will just break down and purchase some aftermarket leafs/shocks/shackles/greasable bushings.
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
