YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-11-2007, 01:53 PM   #1 (permalink)
DirtyDeeds/DirtCheap's Avatar
Synthetic diff. fluid
Anyone using synthetic diff. fluid? If so,what brand and weight.I have a Truetrac rear and stock front.
__________________
2000 4Runner SR5 V6 5spd 4x4
K+N FIPK - Flowmaster 40 - Truetrac,Yukon(rear) -
265/75/16 Mastercraft Courser CT's
DirtyDeeds/DirtCheap is offline
Sponsored Links
To remove this ad, register today!
Old 05-11-2007, 04:50 PM   #2 (permalink)
Nic
Nic's Avatar
Amsoil 80W90 in the rear. 75W90 in the front diff and T case, and transmission. But I had to drain and put Redline MT-90 in the transmission due to poor shifting.
I will go all Redline next time I change out.
__________________
Nic
1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed
Nic is offline
Old 05-11-2007, 04:55 PM   #3 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
im doin a full redline gear oil change soon with 148k on the factory stuff i figured its time
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
mom 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 05-11-2007, 07:23 PM   #4 (permalink)
Texas_Ace's Avatar
Send a message via MSN to Texas_Ace Send a message via Yahoo to Texas_Ace
I am also about to go all syn in my diffs and trasfer case.
The only syn i could find was mobil 1 so that is what i will be using.
Texas_Ace is offline
Old 05-11-2007, 08:42 PM   #5 (permalink)
i just got done putting synthetic in front/rear/trans/transfer today. $40 to do them all
__________________
mine; 02 tacoma e-cab,sr5,4 cyl., 5 speed,
92 dodge 150, 318 mag, nv 4500, np 241, d60 f/r, 305/70/16 on stock wheels
hers; 07 fj, "mall crawler" (for now)
hillbillyjake is offline
Old 05-12-2007, 10:58 PM   #6 (permalink)
kevin444's Avatar
Send a message via AIM to kevin444
I'm using redline 75w90ns with my truetrac its working fine.,
__________________
02 4runner conversion complete!
kevin444 is offline
Old 05-13-2007, 08:29 AM   #7 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
I had the same shifting issue on my 95 4runner with amsoil, found that 25% dino made it shift better. I dont have that issue on my 92 p/u, different trannies so the syncros must be different.
I run AmsOil Severe-Gear 75w-90 in everything. Its even in my 03 4runner, and it loves it, seems to shift itself better, in the xcase.
www.amsoil.com
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 6 Spd, Pricol EGT and boost, 2" Level, Jake Brake, Muffler Delete, filtered, lubed and bypassed by Amsoil, Mag-Hytec Rear, Fast Coolers, Baldwin 7977, Smarty JR SW#1, Toyo 285's...
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 05-13-2007, 10:55 AM   #8 (permalink)
Quote:
Thats what Randy's Ring+Pinion suggested for my Truetrac,just ordered some today,thanks.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Synthetic Transmission fluid jeremys73 General Vehicle Related Topics (Non Year Related) 3 02-11-2006 04:43 PM
Brake fluid or Diff fluid? Gangus2006 95.5-2004 Tacomas & 96-2002 4Runners 20 09-19-2005 09:14 PM
DOT 5 Synthetic Brake Fluid Gentleman 95.5-2004 Tacomas & 96-2002 4Runners 14 01-21-2004 09:23 AM
?? changing tranny fluid + trans case fluid + diff fluid.... sage 95.5-2004 Tacomas & 96-2002 4Runners 1 06-22-2003 09:38 PM
Synthetic fluid question obxfishn 95.5-2004 Tacomas & 96-2002 4Runners 8 05-27-2003 02:53 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
