Sunroof opens (tilts up) by itself? Ideas?
Old 07-20-2010, 04:31 AM
avalonracing's Avatar
Over the past few weeks I've found my '97 SR5 sunroof tilt is open when I didn't open it. I thought that I was crazy but twice yesterday, for no good reason, it tilted up on me in the middle of a drive.
Any ideas as to why this is happening (other than a ghost) and how to stop it (other than pulling the fuse)?
Old 07-20-2010, 05:20 AM
gpcollen1's Avatar
It might be something as simple as the switch. Take it apart and take a look. Maybe grab a replacement out of a junker or other...
Old 07-20-2010, 05:59 AM
tunnelmotor99's Avatar
More than likely there is a short or a loose wire somewhere. I would start at the switch and trace the wires from there. Is it a factory sunroof or aftermarket? If it is oem you should be able to find schematics online.
Old 07-20-2010, 07:34 PM
It's the factory roof. I'll start with the switch, hopefully my search will end there. Thanks.
Old 07-24-2010, 09:27 PM
dave_mcmillan's Avatar
Sounds like its a contact on the switch (bare or loose) causing this. Either that or you have fed the 4runner after midnight (old gremlin reference)...
Old 07-25-2010, 05:34 AM
Actually, it was something with the internals causing the switch to depress it's own mechanism. We just moved things around just a bit and it's all good. Thx.
theking11863
03-19-2016 09:36 PM
kirkrunner
07-27-2015 07:59 PM
calderp
07-27-2015 09:58 AM
toofly1999
07-25-2015 07:09 PM
jackiebrownia
07-20-2015 09:02 AM
Quick Reply: Sunroof opens (tilts up) by itself? Ideas?
