Stupid Fog Lights.....
So I got these Hella Micro DE lights from performance for my 02 SR5 because it didn't have them from the factory. The clip that hold the H3 bulb into place has broken off. This is the second time. Is there any way to fix it or get a new plate to replace it? Has this happened to anyone?
My truck came with the factory fogs and they are a b!tch to deal with. Make sure you lube the screws. Due to the heat generated, they will get stuck over time and will strip when you try to take them off.
Are you sure the clip you're talking about is broken? It acts as a hinge that you need to manipulate to hold the light in place.
Good luck.
Good luck.
justdifferentials
14
06-11-2017 08:36 PM
PNW94Runner
09-29-2015 02:55 PM
Odin
09-24-2015 04:38 AM
