Struts or Shocks
Old Aug 23, 2006 | 03:57 PM
Skrillah's Avatar
Struts or Shocks
Guys I'm sorry to bore you with this probably stupid question. I'm running a 97 4x4, am I running struts in the front and shocks in the back? Or are they all shocks?
Thanks guys
Old Aug 23, 2006 | 04:11 PM
Godzilla's Avatar
You are correct, struts in front, shocks in the rear
Old Aug 23, 2006 | 04:32 PM
Skrillah's Avatar
ok thanks godzilla!
Old Aug 23, 2006 | 04:39 PM
wjwerdna's Avatar
a strut is basically just a shock with an extra mount on it and a spring wrapped around it... mechanically the strut and shock are similar, but dont get them confused
Old Aug 23, 2006 | 09:22 PM
02SE's Avatar
Actually, they are coil-over shocks in front. A strut provides the upper locating mount for the hub/ spindle in a given application.
The upper A-arm on these 4Runners/ trucks provides the upper locating attachment point for the hub.
The coil-over shocks don't perform a hub/ spindle locating function. So they aren't struts.
Old Aug 23, 2006 | 09:40 PM
marko3xl3's Avatar
If that is true or not, I cannot comment on, but most stores will call coil-overs struts (for simplicity). Only if you go to a speciality store that knows their stuff, then they call it a coil-over
Old Aug 24, 2006 | 07:02 AM
gpcollen1's Avatar
When I ordered mine on line, they were all listed as shocks.
ladybugRC
458
Aug 21, 2020 10:41 AM
ZGjethro
Jun 7, 2017 11:04 PM
dirk89
Oct 1, 2015 05:15 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
