Strongest toyota front/rear diff
Old 05-22-2005, 07:25 PM
Praufet's Avatar
What is the strongest front and rear toyota based diff? I think the strongest rear axle is out of the fj80 and I heard the new 4runners have an 8" front diff. What about the strongest cvs? I know the tundra ones are a lot beefier. What do you guys think?
Old 05-22-2005, 07:50 PM
Jared Ajlouny's Avatar
FJ80 front and rear probobly because its a v6 or any other rear diff out of a v6?, i dontknow for sure
Old 05-22-2005, 08:13 PM
Praufet's Avatar
well I still want IFS front, so can't use the fj80 front
Old 05-22-2005, 09:11 PM
kyle_22r's Avatar
fj80 has a 9.25" rear end or something like that. and no cruiser ever came with a V6, most had inline 6 engines
Old 05-23-2005, 10:14 AM
4runner4ever's Avatar
LC80 uses a 8" reverse cut high pinion front and a 9 1/2" rear.
I think those are the strongest toyota makes, except for maybe the LC100 series. I had one of those rear axle's a few months back and the ring gear was a tad larger than my LC80.
Old 05-23-2005, 07:08 PM
Jeff the marmot's Avatar
Tundra CV's are definitely NOT beefier. The inner joint is simply a different design, but they share the same front diff and exactly the same weak point (the breakage point) as the 1st gen Tacos and 3rd gen 4Runners -- the weak, small diameter of the axle shafts at both ends, which is about only 1.1". That's small.
Old 05-23-2005, 07:50 PM
Praufet's Avatar
what about the lc100 cvs? they any beefier?
Old 05-23-2005, 07:56 PM
BruceTS's Avatar
even if you could get beefier axles the jack shaft is still weak, and I totally agree with Jeff the Tundra axles aren't any stronger.......
Old 05-23-2005, 08:11 PM
Praufet's Avatar
just learning here, which part is the jack shaft?
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
Daneums
08-20-2015 05:36 AM
nick b
07-11-2015 04:38 AM
Quick Reply: Strongest toyota front/rear diff
