strobe switch
Old Dec 16, 2002 | 07:07 PM
94 First Responder's Avatar
strobe switch
Most for the emergency guys here: anyone have a switch mounted in the center console of a 2nd gen for your strobe light? Ive been wanted to do it for a while and am tired of tieing up a cig outlet.
Thanks
Old Dec 16, 2002 | 11:43 PM
Sludge's Avatar
I have a switch for my emergency strobe lights,. I put my on the right side of the dash just under the vent. Its connected to a 3 cig outlet i installed.The switch power my dash strobes, 4 corner undercover strobes, and siren. In the pic you can just see the switch thru the steering on the right.
http://community.webshots.com/photo/...57133161gzbyhw
I worry about installing switchs in the center console area. That area gets to dirty and sticky plus i toss my 2way radio their and i know i would hit the switchs and turn them on by mistake
Old Dec 17, 2002 | 04:04 AM
BTOWN4RUNNER's Avatar
I have a dash-mounted strobe and a rotator I throw on my roof. I don't have a switch though. What I did was go to RadioShack and get one of those 3 to 1 cig adapters. Basically all it is is that you put it in the cig lighter and you get three. I use two for my lights and have an extra for whatever. Check that out! :fireman:
Old Dec 17, 2002 | 09:46 AM
i tried a 3 way but it messed up my down shift to 1st. I think I will run a switch in my dash.
Old Dec 17, 2002 | 02:48 PM
Do you think that you could use the OEM switch that we use for foglights? That would be pretty cool and it would look stock. You might even be able to switch the color or the little light to either red or blue, whatever the light is. That might be an option, try that out! :fireman:
Old Dec 17, 2002 | 05:05 PM
I was tossing that idea around myself
Old Dec 18, 2002 | 02:48 PM
I am trying to think how that would work. You would have to cut off the cig adapter and figure out which one is the strobe's ground and ground that to the chasis. Then you would have to put that other wire to the switch. You would then have to get another wire and put it on the switch and run it to a power supply. Lastly, use some more wire to ground the switch. That is the right way I think to set that up. As far as changing the color, you would have to mess around with that. Let me know how you make out. Goodluck. :fireman:
Old Dec 18, 2002 | 09:41 PM
Sludge's Avatar
i grabbed a few stock switches from a wrecked runner over the summer for that very same idea. Also the icons on the switchs can be removed. I want to place a flame icon on the switch for my strobes.:eek:
Old Dec 19, 2002 | 05:21 AM
How are they removed. Do you use some sort of paint remover, or gasoline? Just wondering. Thanks. :fireman:
kawazx636
Oct 6, 2021 03:03 PM
beltcutter
Sep 30, 2015 06:14 AM
PNW94Runner
Sep 29, 2015 02:55 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
