speaker box questions ?
Well I went wheeling yesterday and found out why it is so important to fasen down your speaker boxes . any way I was wondering if it is ok to put screws into the speaker box ? I want to just screw some little brackets on there so I can put a rachet strap on them , or some sort of tie down . I dont want to scre it to the floor because I sleep in the back when I go camping and dont want to unscrew them every time . also I was wanting to mount my amp on the box too, if that is ok .thanx
mount the amp to the back or top of the box since you sleep in the back -- i would mount like corey if you dont lay the seats down and sleep. as for you idea on mounting the brackes go for it!! i was gonna use little tie down strap holders (they have them on mastercraft boat trailers to tie down the cover while on the trailer) but for permant mount i would stick a mounting plate under the box mounted to the floor and then bolt thru bottom of box -- only problem is that you have to takeout the speaker evertime it needs to be removed.
here is somthing you could use for you idea -- if you use bolts instead of screws -- you dont want air coming from these holes so make them tight and maybe some silicon -- i would probally just drill the hole small and hammer the U bolts in
post pics when you finish!!
delmert
09-30-2015 04:34 PM
Esibnitsud
07-30-2015 08:19 PM
rushw
07-18-2015 01:46 PM
crashburnoveride
07-10-2015 06:39 AM
